Sat, Nov 30, 1:43 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 29 1:34 pm)
Subject: Ground Textures - How do I get them to look good?
LMcLean ( ) posted Thu, 07 September 2006 at 2:44 PM · edited Fri, 29 November 2024 at 10:56 PM
I have created a seamless ground texture (1200 x 1200) and have applied it to a plane, but it doesn't look detailed enough in the foreground. Is the texture map large enough IYO?. I set the image X & Y image scale in Vue to 0.015 so it would tile. Any suggestions would be helpful?
bruno021 ( ) posted Thu, 07 September 2006 at 3:25 PM
The texture should be large enough, I suppose you checked the mirror box for the x and y axis?
Also, by plane, do you mean infinite plane? Did you try to map it to a cube to see if it looked better?
Do you have a matching bump map to apply to the plane so it looks less flat? If not, you could create a fractal bump and see if it gets better.
schoesser ( ) posted Thu, 07 September 2006 at 4:18 PM
hhi maybe it woud help for you.. you can scale down or up the texture size on nen object (material editor)
LMcLean ( ) posted Thu, 07 September 2006 at 11:36 PM · edited Thu, 07 September 2006 at 11:37 PM
The texture should be large enough, I suppose you checked the mirror box for the x and y axis? Also, by plane, do you mean infinite plane? Did you try to map it to a cube to see if it looked better?Do you have a matching bump map to apply to the plane so it looks less flat? If not, you could create a fractal bump and see if it gets better.
bruno021 Good idea about adding a bump to the texture. I checked the x and y mirror boxes, but didn't notice any difference. Are the x and y for tiling the material? because the texture didn't tile any differently when I checked the x and y mirror boxes. What are they for? Thanks I will try and post an image tomorrow of the texture.
bobbystahr ( ) posted Thu, 07 September 2006 at 11:43 PM
You didn't mention the version you're using but in thr V5I demo I played with you could go into the I think Basic editor [the one with just 3 windows] and apply the colour map also as a bump and adjust it's height right there. Very Imagine3D like that, found it very handy with bitmap textures....
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
