Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Found it! http://camelot.renderosity.com/tut.ez?Form.ViewPages=703
It's under the main tutorials in the Vue section.
I've started using a program called GeoControl, that does a far better job of creatinf terrain maps than the native generator in Vue. You can create, 3D preview and then save as a grayscale map that can be imported into Vue's terrain module. Their website is http://www.cajomi.de/GeoControl/geocontrol.htm and the have a free trial. Good luck.
I've done a few works trying to capture basalt formations, but the hex column formations (there are also other types) are beyond Vue -- or even GeoControl -- which I have.
I need to work more on this stuff a bit though.
Here is a photo of Palouse Falls I took -- it was raining at the time.
