Quote - You need to apply the map to the transparency channel for your object. This is done differently depending on which version of Vue you are using.
chippwalters, I am including the image and the steps I have taken. I am using Vue 5 Infinite. First Image is the Function Editor. Please tell me how to do this. Thanks
Looks like you got it.
You might check out my tutorial on Mapping a tire:
http://www.altuit.com/webs/altuit2/vuelab/MakingaTire-PartIITextures.htm
and another on Mapping Notes:
http://www.altuit.com/webs/altuit2/vuelab/MappingNotes.htm
I'm having a brain freeze. This is probably something I am overlooking. I want the stripes to be seen only not the Sphere. I have mapped the white line onto the sphere. How do I make the "white" part of the sphere transparent and the dark line to be as is. This is easy using an alpha plane but can I do it with a sphere?
