Quote - whoa! that morph will definitely make it a silly walk IMVHO. raise the hip ytrans up a bit and make it linear.
The morph on her head is the custom Lynara morph from Daz. Does a head morph effect the walking? If so, then I can't change it... how do I fix the walk without removing her head morph?
And I'm not quite sure what you mean by "raise the hip ytrans up a bit and make it linear". Can you explain a bit more please? :) Do I do this because her legs are slightly longer?
Thanks
Ilenora
Quote - check the hip ytrans graph. raise up the value for frame 1. see philc's tutorial if unclear. if ya can raise up the hip so frame 1 looks o.k., then raise all the keyframes by the same amount. the head morph won't affect the walk AFAIK.
Okay, I'll try that thanks :) Where can I find that tutorial please? And um... how will raising the hip make it look okay? It's like her legs sort of bend backwards at the knee when she's walking.
Attached Link: http://www.philc.net/animation1.htm
when ya said "walking like a clown", I guessed a bow-legged silly walk, which might be fixed (assuming IK on) by raising the hip. however, if it's just the shins bending forwards, raising the hip won't fix that, unless ya try the same animation without leg stretch morph, and the shins don't bend forward (IK on).Quote - when ya said "walking like a clown", I guessed a bow-legged silly walk, which might be fixed (assuming IK on) by raising the hip. however, if it's just the shins bending forwards, raising the hip won't fix that, unless ya try the same animation without leg stretch morph, and the shins don't bend forward (IK on).
Sorry, I guess I should have been more explicit :) Well, I made sure IK is turned off, but it's still the same. When I put the default "Sexy Walk" on from the Walk Designer folder in Poser 6, when walks okay, but she walks in place, and when I change the setting to make her walk along a path that's when the leg problem happens. Her shins bend backward, and inwards so that her knees overlap and her ankles get twisted out to be in the right position.
I guess if it can't be fixed I'll just have to try some other animation :) But I have watched other's videos and their figures seem to walk okay :(
Many thanks
Ilenora
save the scaled figure to the figures library and load that cr2 to walk designer .
the head movement can be fixed easily in the keyframe editor.
sexy walk egagerates hip movement and places the feet more in a line or slight crossover. Streatching the legs will give you a lot of grief because the movement will egagerate .
Quote - save the scaled figure to the figures library and load that cr2 to walk designer .
Thanks :) I'll try that. But uh... this may sound stupid but I have no idea how to save the figure to the figures library. Will it still keep it's morphs and textures?
Hi
I'm trying to make an animation using V3 for a contest I'm entering which needs a 40 second movie.
I wanted to make her walk so I used the Walk Designer in Poser 6. I used the Sexy Walk set to 100%, but when I tested it she ended up walking like a clown! So I took the Sexy Walk off and just used the default settings (everything at 0%), but it was almost just as bad as before. What is the problem? Is it that the Walk Designer isn't compatible with V3? I searched in the Free Stuff for some walk animations but the two I found needed the Walk Designer for V3 and the Walk Designer for Millennium Figures, and I don’t know where to find these.
If anyone can help me with this it would be greatly appreciated as this animation needs to be done by early November :)
Many thanks
Ilenora
