Mon, Dec 2, 6:22 PM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Dec 01 9:00 pm)
Check out the
Subject: SILO: Question .. cutting a hole....
BAR-CODE ( ) posted Sun, 22 October 2006 at 9:58 AM · edited Fri, 26 July 2024 at 2:06 AM
Hi there
I can find the solution to this strange thing..
I have a Wall ..i use a Cube to make me a window ..so i cut the Cube out of the wall..
When i work with it this looks OK ..i beveled the sides .. etc etc..
Aslong as im working with it i can see true the hole...
But when i save it as OBJ and reload ..ALL of the extra work is there ..See image B
But i there is no HOLE in the Plane of the wall.. See Image A ..
I think i have to Finalize the work  but i can seem to find HOW to do that..
THnx in advance
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
manoloz ( ) posted Sun, 22 October 2006 at 10:12 AM
Why use boolean in this instance? I believe bridging faces and then beveling gives a more predictable result. I never use booleans in Silo, probably out of habit, so I cannot give you the "scientific" explanation of why it happens...
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
BAR-CODE ( ) posted Sun, 22 October 2006 at 10:19 AM
Well i use Booleans to cut the window because i know what it does :}
I learned the boolean in MAX and it worked in Hex ..so that why i do it this way...
But i thought that make a wall from a cube and then cut out the windows .. was a fast way to do it ...
and i the front face was cut out aswell it is a good way to make wall's is it not ...
Damn im starting to believe i do everything wrong ..with modeling :{
Thnx Chris
Chris
My Free Stuff
Dann-O ( ) posted Sun, 22 October 2006 at 6:12 PM
No it is just that with every modeler you have to approach modeling a bit different.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the person next to me.
Digital_Assassin ( ) posted Mon, 23 October 2006 at 1:01 PM · edited Mon, 23 October 2006 at 1:02 PM
I always model in editable poly, cut, quick slice, chamfer, extrude, weld ... == nice. I hate what boolean does to my models :( takes me longer to clean up its mess than to just do it manually, but i guess yer talkin about silo so, ... not sure if it works the same way :(
