Wed, Feb 5, 8:03 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Annoying Artifacts in C5 Pro with HDRI
StealthWorks ( ) posted Fri, 03 November 2006 at 5:58 PM · edited Wed, 05 February 2025 at 8:01 AM
Hi,
Has anyone had the problem shown in the attached image (marked with the red circles)? I have tried different quality settings, different HDRI maps but the spots are always there in exactly the same place. You can't see it in the image, but theres also a similar artifact in the sky so I don't think the problem is with the skin texture.
anyone have any  ideas?
bwtr ( ) posted Fri, 03 November 2006 at 9:23 PM
I have never found the need to use HDRI maps in the first place! Most images only need  regular 3 point lighting at the best.
Do you have the problem with 3 Point lighting?
bwtr
ShawnDriscoll ( ) posted Fri, 03 November 2006 at 9:26 PM · edited Fri, 03 November 2006 at 9:27 PM
One fix is to turn off Interpolation in your render settings.  Render time will increase a lot.  Setting Interpolation to 100% will make rendering a lot faster, but the ashes might not all vanish.
HDRI works best on reflective objects.
StealthWorks ( ) posted Fri, 03 November 2006 at 9:38 PM
Hmmm, thanks for the suggestion Shonner - I'll try it out.
bwtr - I'll post an image in the gallery tomorrow showing off HDRI lighting. There's no way I could reproduce the effect by using 3 point lighting.
bwtr ( ) posted Sat, 04 November 2006 at 1:34 AM
For interest, the top image is one of those in the Carrara sample light settings for HDRI.
The bottom image is putting a simple left, right and top softbox light setting and rendering at the Carrara default render settings.
(ps the tiles dirtyness is actually in the Carrara original--just dont show up as much!)
bwtr
bwtr ( ) posted Sat, 04 November 2006 at 11:56 PM · edited Sun, 05 November 2006 at 12:01 AM
Here is the lightbox I mantioned. Add it to your Carrara Scenes/Lighting.
Hope you find it of value
(It wont download because a simple zip file is not acceptable.  CRAZY ZRAZY RACYZ!!!)
bwtr
ShawnDriscoll ( ) posted Sun, 05 November 2006 at 12:51 AM
change .zip to .txt, then upload
or is that broke too
bwtr ( ) posted Sun, 05 November 2006 at 1:21 AM · edited Sun, 05 November 2006 at 1:23 AM
OK heres the try!  (the text is zip really!)
AAArrrrrggggghhhh!
bwtr
bwtr ( ) posted Sun, 05 November 2006 at 1:27 AM · edited Sun, 05 November 2006 at 1:28 AM
Heres--MAYBEE-- the .car changed to .txt
What an out of date juvenile site! JEEEEEZ!
bwtr
Patrick_210 ( ) posted Sun, 05 November 2006 at 7:06 AM
Got to be honest, the HDRI image is way better looking than the 3 point setup, IMHO. Of course, when the main object is very reflective, the difference will be more pronounced.
StealthWorks ( ) posted Sun, 05 November 2006 at 7:29 AM · edited Sun, 05 November 2006 at 7:31 AM
Hi
Have to agree with Patrick. There's no competition between HDRI and the 3 light setup. Especially for Poser skin. I was about to post an example of an HDRI Poser scene I set up in Cararra to demonstrate but for some reason Cararra no longer will open the file. It gets to 50% and hangs. This is twice this has happened with two different files in the past day. Looks like I have another issue to get around now :-(
ShawnDriscoll ( ) posted Sun, 05 November 2006 at 3:32 PM · edited Sun, 05 November 2006 at 3:35 PM
Reflective objects need HDRI if they are to look real.
bwtr ( ) posted Sun, 05 November 2006 at 4:44 PM
Thats why photographers use the softbox--as I used in my experiment.
bwtr
StealthWorks ( ) posted Sun, 05 November 2006 at 5:03 PM
Hi Everyone. problem solved!!!
You need to turn the interpolation value up high to avoid those arifacts (mine was sitting at 20%). Shonner thanks for the suggestion.
As promised here is a wee HDRI image.
bwtr - do you think you could reproduce this using just 3 point lighting?
bwtr ( ) posted Sun, 05 November 2006 at 5:36 PM
Maybee if the three lights were inside a circular dome or, as my softbox idea.
If you email me brimar@jbr.com.au I will send you the softbox car file to experiment with.
Actually, photographers use a complete box but, as no background reflections occur  in 3d my setup seems to work quite well.
Ps I will do an exercise to see how it goes with Vic. and post.
bwtr
bwtr ( ) posted Sun, 05 November 2006 at 7:26 PM
Now I must admit defeat. Your HDRI is good.  The attached started with my lightbox then grew extra lights.
Good learning experience for me. Getting more comfortable using lights with each new exercise.
bwtr
ShawnDriscoll ( ) posted Sun, 05 November 2006 at 9:01 PM
Quote - You need to turn the interpolation value up high to avoid those arifacts (mine was sitting at 20%). Shonner thanks for the suggestion.
This confused a lot of old Carrara users at first because Eovia has the values backward for the setting.  Setting it to 0% is the complete opposite of turning if off the way it is now.
ShawnDriscoll ( ) posted Sun, 05 November 2006 at 9:05 PM
I only use distant lights if I use any lights outdoors these days.  And I always use the background for my skylight whether it be HDRI or just a single color.  The camera is always pointed away from the sky in these instances.  Just the ground and object are being rendered.
