Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Quote - I also would like to know why Lemertek's figures, as well as Lyne's Wolves and Lions aren't available for use in DAZ?
These are based on figures that come with Poser.
If you have Poser and the derived figures properly installed, all you should need to do is link the Runtime containing them into D|S.
I wish I was jesting, but I'm a newb when it comes to Daz 3D Poser 6, and Bryce. But I have a little experience in Poser 4. And yes, I would like to use them in Poser 6 and Daz Studio. But I'm going try and import the runtime from Daz and see what happens.
Edit- I tried File-->Import, but that didn't work, so I'm lost with how to import the Daz runtime.
First, when installing the figures, did you select D|S or Poser ?
If you selected D|S, the easiest thing to do is reinstall them for Poser.
If you selected Poser, then in P6, link the Runtime from D|S into Poser, as you would any external Runtime (there are several threads / tutorials on how to do this).
you can also add the poser 6 runtime to D|S - got to edit>preferences>directories> where it says D|S content directories click on that and select poser content directories, go to add and got to where you've got poser 6 stored on your puter. e.g on my puter it is c:program filese frontierposer 6. just select the poser 6 folder, don't use the runtime folder. and hit accept to complete.
um as i said i'm a poser n00b so someone correct me if i'm wrong.
I just downloaded M3 and V3 for Daz, but I would like to use them in Poser 6 and then return them to DAZ.
I also would like to know why Lemertek's figures, as well as Lyne's Wolves and Lions aren't availible for use in DAZ?
