Mon, Jan 13, 3:50 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: I need help using Daz Figures in Poser 6
azureguardian18 ( ) posted Wed, 15 November 2006 at 1:13 PM · edited Mon, 13 January 2025 at 2:35 AM
I just downloaded M3 and V3 for Daz, but I would like to use them in Poser 6 and then return them to DAZ.
I also would like to know why Lemertek's figures, as well as Lyne's Wolves and Lions aren't availible for use in DAZ?
stallion ( ) posted Wed, 15 November 2006 at 2:04 PM
Surely thou jest...
You might as well PAY attention, because you can't afford FREE speech
nruddock ( ) posted Wed, 15 November 2006 at 2:12 PM
Quote - I also would like to know why Lemertek's figures, as well as Lyne's Wolves and Lions aren't available for use in DAZ?
These are based on figures that come with Poser.
If you have Poser and the derived figures properly installed, all you should need to do is link the Runtime containing them into D|S.
Markus_2000 ( ) posted Wed, 15 November 2006 at 2:13 PM
Do you mean Daz Studio when you say using them in Daz?
You want to use them in Daz Studio and Poser 6?
stallion ( ) posted Wed, 15 November 2006 at 2:24 PM
my bad i read that wrong i thought u were going to return them to DAZ the store
anyway can't you import the runtime from DazSTUDIO in Poser
azureguardian18 ( ) posted Wed, 15 November 2006 at 2:29 PM · edited Wed, 15 November 2006 at 2:38 PM
I wish I was jesting, but I'm a newb when it comes to Daz 3D Poser 6, and Bryce. But I have a little experience in Poser 4. And yes, I would like to use them in Poser 6 and Daz Studio. But I'm going try and import the runtime from Daz and see what happens.
Edit- I tried File-->Import, but that didn't work, so I'm lost with how to import the Daz runtime.
nruddock ( ) posted Wed, 15 November 2006 at 4:14 PM
First, when installing the figures, did you select D|S or Poser ?
If you selected D|S, the easiest thing to do is reinstall them for Poser.
If you selected Poser, then in P6, link the Runtime from D|S into Poser, as you would any external Runtime (there are several threads / tutorials on how to do this).
thefixer ( ) posted Thu, 16 November 2006 at 2:37 AM
ROFL@ Stallion, that's what I thought too!!
Injustice will be avenged.
Cofiwch Dryweryn.
L33tace ( ) posted Sun, 19 November 2006 at 8:05 AM · edited Sun, 19 November 2006 at 8:08 AM
don't know if you've worked it out and i'm still a poser n00b but on my rather bad image attached, click on the library icon (1) and then click on the arrow thing (2) and at the bottom it says 'add new runtime' - click that and go and find where your studio content folder is stored on your puter and select that. actually after doing that image i noticed if you use the + button at the bottom right it also allows you to add a runtime.
you can also add the poser 6 runtime to D|S - got to edit>preferences>directories> where it says D|S content directories click on that and select poser content directories, go to add and got to where you've got poser 6 stored on your puter.  e.g on my puter it is c:program filese frontierposer 6.  just select the poser 6 folder, don't use the runtime folder.  and hit accept to complete.
um as i said i'm a poser n00b so someone correct me if i'm wrong.
