DAZ|Studio F.A.Q (Last Updated: 2024 Sep 21 8:54 am)
Attached Link: http://freebackend.daz3d.com/free_weekly/archive_list.php
There are literally hundreds of free stuff to look through here, some of them are Architecture, with floors. Sometimes, you may not see the floor, due to it sitting, just a hair below 0 on the Y axis, but you can select the floor, and move it up to 0 or 1 or 0.5. Also, setting up your lights so you can see the floor (usually by rotating the light source on the x axis) helps immensely.Sitemail | Freestuff | Craftythings | Youtube|
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
its really important to have actual lighting when you use floors. as stated by Jen, the default light that loads when creating a scene only lights things properly which are facing the camera it is not intended to actually light a scene. I highly recommend this tutorial for camera and lighting use http://digilander.libero.it/maclean/DStutorial.htm
OK Steve now YOU of all ppl LOL know that I dont know what the hell Im doing on here LOL sooo do you honestly think I know how to texture it myself HAHAHHAHA, although you have been pretty helpful maybe you might want to teach me that part hehehe. :D
The soul has no window...If the eyes have no tears!
Ok Tina, first what sort of floor do you want? How about polished wood? Right fin a a photo of some wooden panneling. Select your plane, then in surfaces Defuse, click on jpg. This will allow you to use the wood photo (or any other material you have a photo of) still in surfaces, set glossyness to 78% or there abouts and reflection to around 50% (you will most likely have to tweek thesr numbers as I'm at work and trying to do this from memory)lol. Make sure you have some light pointing down at the floor and hopefuly you will have something like a polished wood floor!
If it dont work, let me know and I will try and sort something for you tomorrow when I get home :)
If it ain't free, I can't afford it.
Here's a polished wooden floor I did a while back Tina :)
http://www.renderosity.com/mod/gallery/index.php?image_id=1130143
Ok tina at the top of the screen (assuming you have D/S open)lol. you will see a row of icons. You want the one with a square,circle and triangle in it (i think) these are the DAZ primatives. Select a plane (a 2D square) make it 3 meters big, you can adjust the size if you need to later. Position it at floor level. then goto surfaces and apply your wood photo. I think you will also need to set the difuse colour to white.
I finish work in an hour, then its home to bed (Nightshift) so I will be off line for 8hrs or so.
Catch ya later:)
Hi.... Where do you find flooring for daz?? I've tried a few freebies on here but I cant get them to work for some reason, so Im either dling the wrong ones or doing something wrong. Maybe wrong files?
