Have I told you lately that you're a brat and a tease? :lol: j/k, Teyon, those look great! I'm just waiting (anxiously, and probably a bit impatiently) for the email telling me that I can download my copy. :D
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Mmmm Okay and how did Mr incredible got his hands on P7 ....snifff :}
Looks good ..
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
(Teyon was a beta tester, hence the usage of P7 ;) )
Cool render...is that the cartoon render, or special shaders?
into a fruit salad.
god, that toon render looks great! i would say it's just because of a background, but the edge highlight on the head and neck are wonderful. and the lines!
ooooo, i love the goat.
ok, this has recently been bugging me so i've got to ask. are the sss issues any better? or will we still have to depend on a web of shaders to make skin, wax, leaves, stems, flower petals, stone, plastic, etc., etc.?
and can i say, boy do you know how to light a model. the head looks great.
WOW!! I thought you looked familiar somehow. I pop into the Silo forums here and there to see how things are progressing. I swear between Silo and Poser 7 I might just be able to do something a bit more creative.
I'm quite impressed, that's for sure!!
Thanks for the teases!!
---Wolff On The Prowl---
The SSS is a little better, actually, compared to Poser 6 but it's not perfect and you'd probably be better served with the shader web. I should mention on the toon render that the edge glow is partially due to the shader+light setup and also due to a blur in Photoshop. That's the only one of the images postworked and I should have mentioned that, even if it is a small thing. I don't want folks thinking it can do things it can't (I'd probably get fired). :)
Oh and I'm everywhere, I can't help it.
teyon - is there anyone to pass on to how very important proper sss is? it's the main reason i started using d|s (with pwSurface), and it's in about 90% of materials i want to render. i realize development is done, but if someone can (in the future) make a plugin or service release or something that addresses this, it would be more than wonderful. to even know it's a priority would good. i love poser, and all it's vast power, but if all you guys had done was make it easier to render a humanoid figures (i.e., something with skin), i would have been content.
a list of some materials that require sss
basically, as one expert put it, " All non-metallic materials are translucent to some degree. " sorry, i know this is late to say anything. i'm realizing i should have said something before instead of waiting for it to be one of the reasons, then being silent in disappointment. like i said, i'll be ecstatic if you just tell me that its importance is understood.
i'd say most people use poser to make people, making great skin a high priority. and good sss is key to a realistic and beautiful skin.
thx fr the info, teyon. regarding the "duplicate" function - if it's like the high-end 3D modeller apps, then I believe only one instance of each vertex is stored, not all three. then the software refers to the relative x-y-z positions of the entire duplicate objects to find their vertices. unless it's not actually a "duplicate' function, but just loading the same figure or prop, thrice.
Also keep in mind I am clueless when it comes to this stuff, and I'm sure using a map to tell the computer where and by how much to use the effect would help. These shaders all had translucency along with the simple Fast Scatter. I'm not sure if that's a good thing or a bad thing but they did. They also had it set a bit higher (I think 0.5 in some cases) then the default setting of 0.2.
Here are the same shaders with raytraced lights.
those look very nice! still a bit "hard," and it would be wonderful to see them on your lantern jawed baby, but they're quite a promising beginning. thanks so much for posting them. will they come with your superhero?
oh, and on the talk designer comment: i think he looks like he should be voiced by the guy who did the tick and liono of the thundercats.
"naughty spawn, you face the tick!"
miss nancy - they said it was not instancing in a thread at cp, iirc.
I think it does handle it as instancing, Miss Nancy, so you're probably right about that. I should go back and re-read my docs though to be sure. I should mention to one more time though that I don't do much texture work, I'm pretty specialized when it comes to my skill base, though in a pinch I can make a halfway decent map (like Ssorya or the Sandrunner - blatant plug). However, I also know I'm not even scratching the surface of what Poser can do in the right hands, as I've seen in posts by many of the members here. I hope that the next release will have true sub surface scattering and the option (just the option) to rig a figure using weightmaps or other forms of skinning. As it is, for the money, Poser really does more than many big boys do out of the box (some higher end apps only recently intergrated raytracing alongside their scanline rendering system).
The african american toon character posted earlier actually uses a shader web posted by (and I'm going to screw this up so forgive me) billybaggins with color added to the Clay node. So if you want to compare it to the simple Fast Scatter shaders of similar color also posted, you can.
EDIT:
See, it pays to read first doesn't it Teyon? I just looked at my docs and sure enough, it does not mention instancing. So Poser really is pushing those extra polys! Sorry for the mix up. It's my b-day so I'm a bit wacky.
First off, Happy Birthday Teyon!! I'm going to be all fanboyish and say I love seeing your models. Now that I have that out of my system.
The pic showing the Universal Pose is nice. I'm really curious about that feature. I'd be curious to know more about how the three character rigs differ. I know it's asking alot but it'd be great if you could somehow show an image with the bone setup.
Thanks for sharing.
Hey, thanks! That means alot to me. :)
Well, here are parts where the bodies differ in terms of the actual skeleton:
Simon - has right and left buttocks similar to the other G2 models and Daz Millenium figures. Simon also has a waist in addition to the abdomen.
James Casual - is a standard Poser Propack kind of rig, with no buttocks, only thighs and no waist, only an abdomen.
My toon character has seperate bones for the upper and lower teeth/gums, a waist 1 and waist 2 (I find it bends better on this particular figure), and right and left buttocks'.
Also, both the G2 male and James Casual have dials for things like hand spread and grip, which are often used in these poses. While they simply call for the joints to take certain positions, the hands of my model have not been tweaked and by all rights, should have turned out an awful mess when the pose was applied. The fact it did not was no testament to my rig, as I tried the same mesh in Poser 6 to little joy.
Hope your Birthday celebration was fun!! Happy Birthday to you Teyon!!
Thanks for the heads up on P7, Lightning Man! Dude, I love your models! I can't wait to see more of him! He's sort of "Pixar super-hero meets Sixus1" kind of guy and I love that kind of thing!
It'll be months before I can afford P7, but it's good to see high quality stuff come out it already! ^__^ V,,
I cannot save the world. Only my little piece of it. If we all act
together, we can save the world.--Nelson Mandela
An inconsistent hobgoblin is
the fool of little minds
Taking "Just do it" to a whole new level!
Quote - :) Here's some Fast Scatter skins I made while testing my toons. These were rendered with depth map shadows whose blur radius was set to 2 ( I think I should have increased that). I'll do a render of the same materials with raytraced lights. I'm not a lighting expert (I'm a modeler) so I probably could get better results if I understood lighting a CG scene bit better. Sometimes I miss the good ol' days when we just used paper and pencil to shade a scene. :)
YOW! It looks like they didn't have much improvment for the "Fastscatter" shader, as I can still see the HARD transitions between the shadow, and the FS shader!
Ahhh, that's ok, as it would've "Rendered" my custom shaders moot! I do wish they would've concentrated on the improvement of the FS, or at least introduced REAL SSS as a shader!
From 3DMAX, to C4D they have true SSS shaders, I guess they'll release it in 2010!
Quote - Nope, not a script, it was just shaders listed...I'll find the link.
disappears into darkness
reappears later
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2553769&page=1
I also did a tut on this..
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=37447
It was a fun project, one that I'm STILL working on to this day!
As you all know I've been creating a toon character but what you didn't know was that I was doing it in Poser 7 this whole time. Here's a render showing off the toon, Simon (one of the new Poser 7 G2 default characters), and James Casual from Poser 6. My toon isn't finished having its joint setup tweaked and he has a few extra body parts than the G2 characters and a bunch more than James Casual. Despite the differences in their rigs, I was able to use a Universal Pose on all three which allowed them to take the proper pose with no tweaking on my part. Just three clicks (click the model, double click the Pose).
