Tue, Nov 19, 10:42 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Where is the PoserPython reference manual?
pjz99 ( ) posted Sat, 16 December 2006 at 8:46 PM · edited Tue, 19 November 2024 at 8:58 AM
I've been through my own docs and I've spent quite some time searching Google and e frontiers' website, and I can't find just a basic reference for PoserPython.  I don't need a "getting started" tutorial, I'm pretty comfortable with scripting and I can read existing python scripts and make sense out of them.  What I'm looking for is a reference that enumerates what all the functions are, what their inputs and outputs are, and the like.  Any advice appreciated, thanks.
My Freebies
svdl ( ) posted Sat, 16 December 2006 at 8:51 PM
There should be a PoserPython .PDF manua in your Poser root folder.
My gallery   My freestuff
pjz99 ( ) posted Sat, 16 December 2006 at 9:01 PM
There is, and I've looked through it, but it doesn't contain a list of function names, documentation of their inputs and outputs and syntax, etc.
My Freebies
svdl ( ) posted Sat, 16 December 2006 at 9:17 PM
What I have in PoserPython Methods.pdf looks like this: (just one sample)
Method Name CreateValueParameter Explanation Creates a value parameter on the universe actor. This type of parameter is not linked to Poser elements such as figures, props etc. Rather, it can be used to add user interface control to you Python scripts Arguments Enter a name for the new parameter Syntax CreateValuePrameter( valueParmName) Example parm=actor.CreateValueParameter("MyNewParameter") It's not as extensive as I would have liked, but it's the best I've got. I don't know of a more comprehensive PoserPython manual.
svdl ( ) posted Sat, 16 December 2006 at 9:19 PM
Drat, tables won't work. Here's a screenshot:
pjz99 ( ) posted Sat, 16 December 2006 at 9:23 PM · edited Sat, 16 December 2006 at 9:27 PM
What's the name of that file please?  I had looked through my poser app home directory and found a poser(something).PDF and maybe I missed that in the contents, that's exactly what I'm looking for.
edit: duh reading your previous post, sorry
Edit2:  I may be colossally dense but I can't recall seeing a "PoserPython Methods.pdf" in my poser app home dir, or I would have pounced on it.  Well, now I'm stuck at work or I'd go look into it immediately.  Thanks very much for the push in the right direction (duh)
My Freebies
svdl ( ) posted Sat, 16 December 2006 at 10:43 PM
The filename depends on the Poser version:
Poser 5: PoserPython Methods.pdf
Poser 6: PoserPython Methods.pdf
Poser 7: PoserPython Methods Manual.pdf
I don't have Poser Pro Pack, so I don't know how that file is called.
The files are in the Poser root dir, for all Poser versions I have.
pjz99 ( ) posted Sat, 16 December 2006 at 11:32 PM
I have v6 and v7, when I get home from work I'll go straght at it again and check.  Thank you for the info.
My Freebies
pjz99 ( ) posted Sun, 17 December 2006 at 7:31 AM
Sure enough, there it is.  Obviously I need to increase my caffeine intake.  Thanks again!
My Freebies
