Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
There should be a PoserPython .PDF manua in your Poser root folder.
There is, and I've looked through it, but it doesn't contain a list of function names, documentation of their inputs and outputs and syntax, etc.
What I have in PoserPython Methods.pdf looks like this: (just one sample)
Method Name CreateValueParameter Explanation Creates a value parameter on the universe actor. This type of parameter is not linked to Poser elements such as figures, props etc. Rather, it can be used to add user interface control to you Python scripts Arguments Enter a name for the new parameter Syntax CreateValuePrameter( valueParmName) Example parm=actor.CreateValueParameter("MyNewParameter") It's not as extensive as I would have liked, but it's the best I've got. I don't know of a more comprehensive PoserPython manual.
What's the name of that file please? I had looked through my poser app home directory and found a poser(something).PDF and maybe I missed that in the contents, that's exactly what I'm looking for.
edit: duh reading your previous post, sorry
Edit2: I may be colossally dense but I can't recall seeing a "PoserPython Methods.pdf" in my poser app home dir, or I would have pounced on it. Well, now I'm stuck at work or I'd go look into it immediately. Thanks very much for the push in the right direction (duh)
The filename depends on the Poser version:
Poser 5: PoserPython Methods.pdf
Poser 6: PoserPython Methods.pdf
Poser 7: PoserPython Methods Manual.pdf
I don't have Poser Pro Pack, so I don't know how that file is called.
The files are in the Poser root dir, for all Poser versions I have.
I have v6 and v7, when I get home from work I'll go straght at it again and check. Thank you for the info.
Sure enough, there it is. Obviously I need to increase my caffeine intake. Thanks again!
I've been through my own docs and I've spent quite some time searching Google and e frontiers' website, and I can't find just a basic reference for PoserPython. I don't need a "getting started" tutorial, I'm pretty comfortable with scripting and I can read existing python scripts and make sense out of them. What I'm looking for is a reference that enumerates what all the functions are, what their inputs and outputs are, and the like. Any advice appreciated, thanks.
My Freebies
