Sat, Jan 25, 4:43 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: Problem with "Duplicate with Symettry" Command
Pinklet ( ) posted Fri, 22 December 2006 at 11:48 AM · edited Sat, 25 January 2025 at 4:34 PM
Why is my object not aligning with the opposite plain when I use the Duplicate with Symmetry Command. I have tried re alleging the joint and still it seems to think the axis is skewed. What am I missing?
bwtr ( ) posted Fri, 22 December 2006 at 8:39 PM
Maybe your question is not clearly enough described or illustrated?
bwtr
Pinklet ( ) posted Fri, 22 December 2006 at 9:31 PM
The illustration shows the top 3/4 view of my models bone structure. As you can see. everything is symmetrical. The red lines represent the arm beginning at the shoulder joint. When I first placed the bones, if I used the duplicate with symmetry command I would get a perfect mirror image. Now I get a perfect mirror image but it seems now Carrara is using a different angle to mirror the bones. How can I control the axis that Carrara uses to mirror the item. The selected blue area is where Carrara is placing the arm, the red area represents where I expected the bones to be using the command. Dose this make sense now? English is my second language so please bare with me.
bwtr ( ) posted Fri, 22 December 2006 at 11:41 PM · edited Fri, 22 December 2006 at 11:45 PM
Attached Link: http://http://forums.polyloop.net/carrara-tutorials/5004-c5-rigging-skinning-bones-setup.html
That explanation helped a lot. Wish I could use a second language as well.
I presume you are installing the bones using a 4 point view ( your bones are in the right place in all dimensions)?
I am having a difficulty also today--there is a tute --I will try and find it
bwtr
bwtr ( ) posted Sat, 23 December 2006 at 12:12 AM
Even after following that very good tute, you still may find the axis revolve-as attached screen shot-- to be of use I think.
Hope that solves all your problems.
bwtr
bwtr ( ) posted Sat, 23 December 2006 at 12:16 AM
bwtr
Pinklet ( ) posted Tue, 26 December 2006 at 2:54 PM
Thanks for your help. Under closer inspection the bone that I was generating the arm from was not facing forward exactly. That was the reason why it looked turned.
