Tue, Nov 26, 2:47 AM CST
Subject: Has anyone made a script to turn off texture filtering off?
Tashar59 ( ) posted Sun, 24 December 2006 at 4:45 PM · edited Tue, 26 November 2024 at 12:04 AM
I think it sucks big time having to turn texture filtering off all the time. What was eF thinking , again. (knocks on eF forehead, Hello, any body occupy this space?) Anyhow, has a py script been made yet? What do I need to bribe someone with to get one made?
I know, I need to learn how to do py scripts myself, I hate having to ask for anything.
FSMCDesigns ( ) posted Sun, 24 December 2006 at 5:07 PM
Funny, i find the opposite. Most of the hair I like to use looks like crap if texture filtering is off. I would prefer to have it on, but it does kill resources which is why I don't render in poser 6 (haven't tried P7 yet) any longer.
Regards, Michael
My DeviantArt page
nruddock ( ) posted Sun, 24 December 2006 at 5:13 PM
Attached Link: http://www.keindesign.de/stefan/poser/scripts/p7/turn%20off%20texture%20filtering.py
> Quote - Anyhow, has a py script been made yet?
stewer wrote one (save attached link).
Tashar59 ( ) posted Sun, 24 December 2006 at 5:21 PM
Thank you very much.
It looks ok on some hairs but really blurs skin textures. I think the individual map ideal was good, but it should have been turned off as the standard. This way you could just turn the maps for hair on and not waist so much time the other way.
nruddock ( ) posted Sun, 24 December 2006 at 6:13 PM
Quote - Most of the hair I like to use looks like crap if texture filtering is off.
The transmaps used for hair usually have very fine detail, so you need to use a smaller value for the shading rate.
For P7, there shouldn't be resource problems with Texture Filtering due to the new texture paging code.
4blueyes ( ) posted Sun, 24 December 2006 at 6:43 PM
Quote - > Quote - Anyhow, has a py script been made yet?
Wow, thank you very much for the link! I thought I'm going to get crazy lol Never used texture filtering as it eats RAM in huge quantities :) Michal 4blueyes
Little_Dragon ( ) posted Sun, 24 December 2006 at 7:28 PM
Quote - Never used texture filtering as it eats RAM in huge quantities :)
I ran some brutal test renders with P7 last night ... the same scene twice, first with filtering enabled on all textures, and again with filtering completely disabled.   I couldn't detect any significant impact on resources.  It used almost exactly the same amount of memory, to within a few kilobytes.
Didn't time them, unfortunately, so I don't yet know how much this new filtering affects render speed.
I'll admit this, though ... P6 could never finish rendering that scene file on its own without some major compromises on my part.   There have definitely been some changes for the better.
Angelouscuitry ( ) posted Sun, 24 December 2006 at 9:16 PM
What is texture filtering supposed to do?
Where is it controlled from?
stewer ( ) posted Sun, 24 December 2006 at 9:32 PM
Quote - For P7, there shouldn't be resource problems with Texture Filtering due to the new texture paging code.
Correct. Enabling texture filtering in Poser 7 will not increase memory usage, at all.
Little_Dragon ( ) posted Sun, 24 December 2006 at 10:48 PM · edited Sun, 24 December 2006 at 10:49 PM
Quote - What is texture filtering supposed to do?
Texture filtering is used to reduce or eliminate moiré patterns and other artifacts that may otherwise appear in finely-detailed textures.  It can help with hair materials in Firefly, for instance.
Quote - Where is it controlled from?
In Poser 7, texture-filtering is controlled from the material room, as an option on each image-map node.  It defaults to Quality, but can also be set to Fast or None.
stormchaser ( ) posted Mon, 25 December 2006 at 1:44 AM
Just wondering then, for skin detail, is it best to have texture filtering on or off? When I used to render in Poser 6 I think I had better detail with it turned off.
Angelouscuitry ( ) posted Mon, 25 December 2006 at 3:01 AM
Thanks Little Dragon!
Merry Christmas!
Puntomaus ( ) posted Tue, 26 December 2006 at 5:31 AM
Quote - Funny, i find the opposite. Most of the hair I like to use looks like crap if texture filtering is off. I would prefer to have it on, but it does kill resources which is why I don't render in poser 6 (haven't tried P7 yet) any longer.
I never used texture filtering but set the MinShading rate to about 0.02 in the Render settings. Hair, brows and lashes turned out perfect.
Tashar59 ( ) posted Tue, 26 December 2006 at 3:43 PM · edited Tue, 26 December 2006 at 3:44 PM
"I never used texture filtering but set the MinShading rate to about 0.02 in the Render settings. Hair, brows and lashes turned out perfect."
That's what I do too. I also find that scaling the figure up makes a big difference. Great for close-ups.
