Mon, Feb 3, 7:57 PM CST
Subject: Nerd's Catrina figure and joint issues
Kalypso ( ) posted Thu, 28 December 2006 at 2:17 PM · edited Mon, 03 February 2025 at 7:56 PM
Site Admin
Needing a sphinx for an illustration I decided to use Nerd's Catrina figure (available here in Freestuff).  I remember working with this figure when I first downloaded it years ago and it didn't have any problems.   However, now when I try to bring it in Poser 6 or 7 I get the results you can see in the image.  Something very weird is going on with the arm joints where the P4woman's blend with the animal's.   I tried zeroing joints and re-applying the poses Nerd supplies but I still have the same problem.
Has anyone experienced something like this?  Is there a workaround for P6 or 7?
Installing P4 is not an option as there are other items I'll also be using that cannot be used in P4 correctly.
Miss Nancy ( ) posted Thu, 28 December 2006 at 2:47 PM
turn off IK, restore figure?
Ghostofmacbeth ( ) posted Thu, 28 December 2006 at 2:49 PM
It looks like it could be IK but it might just be a glitch in the versions. (the joints have changed along the way to s small degree). I get locked points and feet sometimes on things I test but I don't really know how to fix them. Just know how to pint them out.
Kalypso ( ) posted Thu, 28 December 2006 at 3:04 PM
Site Admin
IK is not turned on by default.   Anyway I zeroed joints and it looks fine with it's arms outstretched.  When I try to bend the arm it goes all wacky again.
Restore figure just returns the figure to it's default position, the one I showed in my first posting with the arms twisted.
Here it is with joints zeroed.
Kalypso ( ) posted Thu, 28 December 2006 at 3:05 PM
Site Admin
And here's what happens when I try to pose the arm.
nerd ( ) posted Thu, 28 December 2006 at 4:14 PM
Forum Moderator
Yup, it's doing it to me too. I honestly haven't loaded this up in years. Give me a bit to see if I can figure it out.
nerd ( ) posted Thu, 28 December 2006 at 5:05 PM
Forum Moderator
Attached Link: Updated Catrina
Here you go, Fixed to work in P6 and up. Just re-download and replace the files. You will find a P6 version in the Zip file.
JoePublic ( ) posted Thu, 28 December 2006 at 5:09 PM
"Here you go, Fixed to work in P6 and up. Just re-download and replace the files. You will find a P6 version in the Zip file."
Do you mind explaining what exactly the problem was ?
nerd ( ) posted Thu, 28 December 2006 at 6:56 PM
Forum Moderator
I didn't really examine the files. I just recreated the joints for the arms. You could try examining the two files and see what is different.
Miss Nancy ( ) posted Thu, 28 December 2006 at 7:55 PM
it looks like he fixed the elbow JPs, e.g. the rotation centres (zyx).
Kalypso ( ) posted Thu, 28 December 2006 at 8:37 PM
Site Admin
Thank you :)  That was fast!
