Sun, Feb 16, 4:07 PM CST
Subject: Bryce `s export mat help needed!!!
amlan70 ( ) posted Wed, 10 January 2007 at 1:12 PM · edited Fri, 14 February 2025 at 4:32 AM
**HI all,             Hope everyone is fine...I am back after a logtime..Wish  you all a very Happy & prosperous new year .             Needed to know something.If say I ever need to export a material from Bryce as *.mat how do I apply it in 3d max ??? ANy idea..I have attached a screen capture to highlight what I mean !! Waiting for the expert views !!
Thanks
Amlan70**
amlan70 ( ) posted Wed, 10 January 2007 at 1:21 PM
**You can see in max if I apply the same mat , it does`nt show in the render though it show applied !! Can someone tell me how to apply the mat ??
Thanks
Amlan70**
danamo ( ) posted Wed, 10 January 2007 at 1:27 PM
It cannot be done! The Bryce procedural materials and the 3D max shaders are totally incompatible. It makes about as much sense as trying to mate a horse with a goat.
Incognitas ( ) posted Wed, 10 January 2007 at 2:23 PM · edited Wed, 10 January 2007 at 2:26 PM
Well I can see the point of a gorse or a hoat...But it really is a bit much to expect overall standardisation across all 3D software.That there is as much standardisation as there is, should applauded especially as most software developers have so many different OS's to contend  with before any other considerations. ;)
Death_at_Midnight ( ) posted Wed, 10 January 2007 at 2:32 PM
It's been years since I touched 3D Max. I was reading last week in some of the other forums here how some people were exporting Bryce 6 materials to their heretical software by exporting objects from Bryce with the material applied, then importing that object to the other software.
danamo ( ) posted Wed, 10 January 2007 at 3:08 PM
True, Death_at_Midnight, but the exported object has the material sort of "baked-on" as an image texture, and not as a procedural .mat. You might as well do the old trick of rendering an image of the Bryce procedural on a plane, or 2D square from a topside view, and export that as a bitmap texture.
amlan70 ( ) posted Wed, 10 January 2007 at 8:31 PM · edited Wed, 10 January 2007 at 8:35 PM
BUt Danamo I am sure there must be someway .Can it done something like this ?? we export the whole group as obj out of Bryce .Like this...Now as you know,there almost 6-7 exporting formats out here apart from obj.
amlan70 ( ) posted Wed, 10 January 2007 at 8:34 PM · edited Wed, 10 January 2007 at 8:34 PM
You can see what I got when I am exporting.And then import in max .as likely while rendering it Max looks for the bmp s. But even if Inotify their paths I get no texture.BUt under intense direct target light .... I saw some texture on the rings !! any idea ...how to get it better withthe sameshine as Bryce ??
danamo ( ) posted Thu, 11 January 2007 at 12:53 AM
No, it cannot be done. And I don't care how sure you are. The shader languages of 3D Max and the material lab of Bryce are based on entirely different mathematical formulae. There is no format you can use that will successfully translate the exact look of a Bryce metallic, or other procedural material into 3DMax, or any other application for that matter. Better start learning how to use 3dMax's shader language if you are going to render your Bryce models there. I'm done.
TheBryster ( ) posted Thu, 11 January 2007 at 4:20 AM
I am very disappointed with Amlan. He has confessed to owning Heretical software. The Cardinals are not going to be pleased....................
amlan70 ( ) posted Thu, 11 January 2007 at 4:47 AM
Thanks Danamo I wd try to learn more .Bryster I dont understand what do you mean by it ...why are u so displeased ???
TheBryster ( ) posted Thu, 11 January 2007 at 4:50 AM
Amlan: Just joking.  3D Studio Max is an app from the 'Dark Side'. To use it is therefore Heresy! Happy New Year!
amlan70 ( ) posted Thu, 11 January 2007 at 5:03 AM
Hihi : > I knew u r after something...and hws everything Chris ?? Great Chris ...hope you r in great health ...Give my warm wishes to your family for a great new year !!  If someone wdnt have given me any reply I wd have written u a mail . Fro everyone BRYSTER  & GRYLIN is my great teacher ...all that I have learnt about Bryce .  Keep in touch dear !!
pakled ( ) posted Thu, 11 January 2007 at 12:05 PM
What I do in Wings (backsliding, but not outright heresy..;), is I'll open Bryce, create a cube (2d surface would probably work as well, but I'm lazy..;) texture it, and fiddle with lighting, etc., until I get what I want. Then I fill the whold screen with it, and Save Image As. (jpg usually, but if you have a lot of time and disk space, you could default to bmp..;).
Then go to your modeling program, and import the image as a texture (if Wings can do it,  I'm sure lightwave can..;)  that's about the only way. I've managed to do a coupla dozen mats this way, and so far, it's worked.
danamo ( ) posted Thu, 11 January 2007 at 12:19 PM
No offense Pakled, but I would never save an image out of Bryce as a .jpeg instead of a .bmp.
Maybe it's changed since the introduction of ver.6, but Bryce is notorious for having a really bad .jpeg compression scheme, full of pixelization, artifacts and such. Better to export as a .bmp and then take it into an image editor to compress to jpeg.
pakled ( ) posted Thu, 11 January 2007 at 7:03 PM
eh..I've used both. Worth a shot...I'll try it..;)
