Fri, Jan 10, 6:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Headlights?
DigitalDreamer ( ) posted Sat, 13 January 2007 at 4:15 PM · edited Fri, 27 December 2024 at 11:56 AM
I'm rcreating a pic that includes a motorbike, riding after dark.
I want to make it look as if the bike's headlight is casting a beam of light. I tried setting up a spotlight inside the headlight, but the light did not throw a beam.
Anyone got any ideas how this can be done in Poser 7?
Many thanks
DD
BAR-CODE ( ) posted Sat, 13 January 2007 at 4:22 PM
Attached Link: http://www.renderosity.com/mod/tutorial/index.php?tutorial_id=956
This will work... read the tut here online
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
thefixer ( ) posted Sat, 13 January 2007 at 4:23 PM
Spotlight with the end of the light just ahead of the bikes headlight and use Volumetric light!
Injustice will be avenged.
Cofiwch Dryweryn.
DigitalDreamer ( ) posted Sun, 14 January 2007 at 4:22 AM
Thanks guys
raven ( ) posted Sun, 14 January 2007 at 7:52 PM · edited Sun, 14 January 2007 at 7:53 PM
Here's a way to do it without using volumetric light, which can sometimes take a while to render. The top picture shows a resized cylinder primitive, rotated and positioned to simulate a lightbeam from the bike's light. The lower part of the picture shows the material room set-up for the lightbeam effect. You can vary the transparency and the colour for differing effects.
Click the picture to see it bigger.
Hope that helps :)
thefixer ( ) posted Mon, 15 January 2007 at 2:12 AM
Hey that's a neat trick Raven, see even I've learnt a new technique!
Wonderful place innit!!
Cofiwch Dryweryn.
Acadia ( ) posted Mon, 15 January 2007 at 2:36 AM
Wow! Thanks for that!  I'm going to add this to the material room / shaders bookmarks link!
dphoadley ( ) posted Mon, 15 January 2007 at 2:57 AM
Attached Link: Bear Buck Naked.01 (Warning: Nudity)
**dphoadley @****raven **I just used your suggestion in my lastest gallery upload.  Thank you for the great idea. David P. Hoadley
Acadia ( ) posted Mon, 15 January 2007 at 4:05 PM
Great image David!  The lighting works very nicely!
BAR-CODE ( ) posted Mon, 15 January 2007 at 4:11 PM
Yup .. i use the almost the same thing for laser beams .. and laser fire ...
Chris
Chris
My Free Stuff
LostinSpaceman ( ) posted Fri, 19 January 2007 at 6:49 PM
Might I suggest a cone instead of a cylinder? Light spreads.
raven ( ) posted Sat, 20 January 2007 at 5:12 PM
I used the cylinder only because it worked better than the cone would due to the point of the cone. However, I have since made a couple of conical tube variations, one that would be suitable for a torch for example, and one more suited to headlamps. Here's a small example pic to show them. It's a blended render and screencap.
