Sat, Jan 11, 3:32 AM CST
Subject: Q: Object scaling in pp2 files
Holli ( ) posted Mon, 22 January 2007 at 3:22 PM · edited Fri, 10 January 2025 at 9:30 PM
Hello,
I created a prop with a reference to and external obj file.
After I reload the prop the object is very large. It is no problem to scale the prop down with the dials and save it again but when I reload the prop again the scale value is not 100% anymore.
How do I reduce the size of the object and remain a default size value of 100% ??
Or how do I reduce the size and set the displayed value to 100% ??
thanks
Holli
markschum ( ) posted Mon, 22 January 2007 at 3:31 PM
Hi, scale the object in poseer , then export the obj file. Replace your object file with the one exported. That should then load at 100% scale and be the correct size in poser .  I think.
I usually import to poser, scale for size, then load the object back into the modeller, and resize it there
BeyondVR ( ) posted Mon, 22 January 2007 at 4:10 PM
That will fix the OBJ, but the original PP2 will now be wrong.  Open Poser and import the prop again, then set the scale back to 100%.  Now save the PP2.
Another thing that is often skipped is the center point.  In outline display mode, open the hierarchy window, with the prop selected.  You should see a green cross, which is the center point.  Your cursor will change to a bull's eye when you hover over it, and you can move it.  Place it where you want the prop tp pivot.  If it's out in space, the prop will behave oddly.
If you don't see it, type 0.000 in all the center point boxes, and pick it up off the ground.
John
geep ( ) posted Tue, 23 January 2007 at 3:34 AM · edited Tue, 23 January 2007 at 3:35 AM
Hi Holli,
Or you can try this method ...
  1. In Poser, change the scale of the prop to the desired size
  2. Use the Group Edit tool to Create a NewProp, i.e., duplicate* the prop
  3. Save the NewProp
The new prop will have all of it's "Scale" parameters set to 100%.
cheers,
dr geep
  • (Group Edit Tool) ... Make New Group ... Add All ... Create New Prop
Note - You may want (or need) to readjust the "center point" (origin) of the NewProp
cheers,
dr geep ... :o]
edited 10/5/2019
Holli ( ) posted Tue, 23 January 2007 at 3:35 AM
This sounds so easy I will try it!
geep ( ) posted Tue, 23 January 2007 at 3:40 AM
:biggrin:
cheers,
dr geep ... :o]
edited 10/5/2019
Holli ( ) posted Wed, 24 January 2007 at 5:47 AM
Ok, I did it!
My obj already had some groups so I added all together and created a new prop from that.
But a little problem remains.
If I save this new created prop it has internal geomerty.
BeyondVR ( ) posted Wed, 24 January 2007 at 6:31 AM
Or you could have done it the easy way, and been done with it ;)
John
nomuse ( ) posted Thu, 25 January 2007 at 5:21 PM
That's why I also find it easiest to make corrections in the Poser workspace then export as .obj. If I start with a prop that has external geometry, I can open (or import it) in Poser, make changes with scale, Grouping Tool, magnets, combine it with other objects....export the entire mess, name it the same as the original object.....now when I click on the old library entry I get my old prop with all the old materials and settings, but new geometry (and still external). (Just this weekend modified a pair of easy-pose instrument cables; imported both to Poser, selected the cord from one and the ends from the other, exported the franken-object, and by making a duplicate of one of the original cr2's I now have a completely new figure).
