Tue, Jan 21, 9:39 PM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2025 Jan 21 7:59 pm)
Subject: Need FE help in regards to error reading!
DreamersWish ( ) posted Wed, 24 January 2007 at 8:58 PM · edited Tue, 21 January 2025 at 4:09 PM
I was trying to look at some old FE spotfiles I had made in the past.  When I tried to bring them up in FE  I kept getting these error reading: "Create comple process failed; System error: The perameter is incorrect." Then I would get "DLL not compiled.  Make compilation window visible and check for errors in the formula code."
Is there anyone who might know what is going on.  I have a lot of spotfiles from that time that appearently used that same sort of perameter.  I would appreciate any help if possible.  Thank you for taking the time to look and any help given.
Pannyhb ( ) posted Thu, 25 January 2007 at 10:27 PM
Which version of FE are you using?  Some of the newer versions are either incompatible with old spot files or need a little tweaking.  Also - is your formula compiler unzipped into your main FE folder?
DreamersWish ( ) posted Fri, 26 January 2007 at 11:05 AM
The version is 2.02.  As far as I can tell the compiler is in my main FE folder.  I have made an FE file that has all the unzipped items that it came with (v. 2.02) and added the compiler.  Have I put it in the wrong place?  Thank you so much Pannyhb for the help.  I truly appreciate it.
