Tue, Jan 7, 9:25 PM CST
Subject: Perpective Problem? Help
Uncle_Riotous ( ) posted Fri, 26 January 2007 at 6:23 PM · edited Mon, 06 January 2025 at 4:16 PM
I dabble with Bryce from time to time and I'm getting back into it at the moment.  I've got a really nice scene with some great buildings and towers but every time I go to render it the perspective bends all the towers in at the top.
I've tried to search the net for answers but I've drawn a blank.  What I want to do is to render the image but leave straight things like really narrow towers looking straight.  I've attached a quick render to show you what I mean.
Help.
pakled ( ) posted Fri, 26 January 2007 at 7:25 PM
hmm...what happens if you lower the camera closer to the ground, and point up slightly?
TheBryster ( ) posted Fri, 26 January 2007 at 7:46 PM
Forum Moderator
I think I know what you did wrong.
Go to the wireframe.
Click the + icon on the bottom right of the GUI. to bring your scene closer.
You might want to do this a couple of times.
Then use the arrows above the big render button to push your scene further away to give you your desired perspective.
Now render.
Things should be back to normal, but sometimes it's trial and error.
skiwillgee ( ) posted Fri, 26 January 2007 at 10:13 PM · edited Fri, 26 January 2007 at 10:13 PM
I think Bryster has quessed the correct problem.  If that isn't it, check the camera settings.  Click the tiny inverted triangle just above and right of the track ball. In the pop up menu select "edit camera".  See if scale value is something other that default 100%.  Changing that value will effect the scene.
Uncle_Riotous ( ) posted Sat, 27 January 2007 at 12:27 AM
Thanks guys.  I'll give that a try straight away.  I've had the problem before but this time I just had to find out how to solve it.
Uncle_Riotous ( ) posted Sat, 27 January 2007 at 1:08 AM
It works, thanks again.  Not only does it work but I understand why.
TheBryster ( ) posted Sat, 27 January 2007 at 6:00 AM
Forum Moderator
You're welcome!
CrazyDawg ( ) posted Sun, 28 January 2007 at 3:40 AM · edited Sun, 28 January 2007 at 3:40 AM
Quote - It works, thanks again.  Not only does it work but I understand why.
god someone understands Bryster, could mean trouble for us on earth.
I have opinions of my own -- strong opinions -- but I don't always agree with them.
TheBryster ( ) posted Sun, 28 January 2007 at 8:44 AM
Forum Moderator
:lol:
