You want multicolored highlights? Don't really understand what you want to achieve, would be good to see the original model to better underdtand. You can do many things in the function editor to edit highlights.
When in the advanced material editor, you'll notice that highlihght colour, highlight intensity and highlight size have a lightning icon before their name. This means that this constant parameter cxan be extracted and edited in the function editor. And you can create a variable function as well.
Si I would extract the constant colour parameter, and replace this K node by a colour map node, and choose color correction-HSL shift, and tick "allow luminous colours". I would then create another colour node connected to this hsl shift node, make this node a gradient. Edit the gradient colours, and then play with the hsl sift. This node is only here to make your gradient luminous, but since it shifts hsl values, it will change your gradient colours a lot.
Then back in your viewports, check how everything looks now.
Bruno,
Please explain what you are talking about.
I think I know a little about Vue, in the short time I have played with it.
But I have no idea what you are talking about. As I am sure, that anyone 'lower' in base knowledge would have less of a clue.
Maybe the OP is more advanced than me, and understands you. Hope so. I don't.
I have Vue 6, and have imported a model of the movie version of the starship Enterprise into the program. I've played around with the settings, and tried working with the function editor, but I would like to know if there is any method to produce multi-colored highlights from the model, to produce the iridescence of the original. From what I can tell of the function editor, highlights end up being produced by a number, and there is no way to connect a color map to a function for highlights. I've attached an image of what I have so far.
thanks,
greg
