Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
You can't use black for the reflected color, but as long as you have a light color there everything should render with highlights, as on the shoe on the left, which is set to pure black. The shoe on the right has a reflection map, I've never been happy with the results of combining texture maps with reflection maps (as the two seem to fight each other), but reflection works O.K. with a bump map.
Tried to make a black texture map for some boots, but they wouldn't render with any highlights, no matter what I did. Discovered that black objects simply don't reflect! A lighter colored texture map turned to black with the texture/object color dials works jes fine. I suppose the answer is to use a reflection map for black textures???
