Sat, Feb 1, 4:53 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: odd observation re black textures and reflections
mikes ( ) posted Thu, 10 May 2001 at 12:10 PM ยท edited Sat, 01 February 2025 at 4:49 AM
Tried to make a black texture map for some boots, but they wouldn't render with any highlights, no matter what I did. Discovered that black objects simply don't reflect! A lighter colored texture map turned to black with the texture/object color dials works jes fine. I suppose the answer is to use a reflection map for black textures???
Jim Burton ( ) posted Thu, 10 May 2001 at 12:32 PM
You can't use black for the reflected color, but as long as you have a light color there everything should render with highlights, as on the shoe on the left, which is set to pure black. The shoe on the right has a reflection map, I've never been happy with the results of combining texture maps with reflection maps (as the two seem to fight each other), but reflection works O.K. with a bump map.
Jim Burton ( ) posted Thu, 10 May 2001 at 12:34 PM
Opps, wrong pic!
JeffH ( ) posted Thu, 10 May 2001 at 3:31 PM
Uncheck "Apply texture to Highlight" and see if that makes a difference. -JH.
morganza ( ) posted Thu, 10 May 2001 at 7:20 PM
I've put some time into this problem and this is what i came up with: 1: Make the object color white( the area you want highlights) 2: Load the silver reflection map and check the two boxes under it. 3: Select highlight to white at 75% 4: Set the reflection color to 111,111,111. Hope this helps, Morgan
mikes ( ) posted Thu, 10 May 2001 at 10:49 PM
Jeff--thanks, that worked. Of course a black highlight on a black texture will be invisible!... (slapping forehead)......
