Sun, Nov 10, 11:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 11:00 pm)
Subject: Walk Designer
freefall565 ( ) posted Wed, 07 March 2007 at 10:50 PM ยท edited Sat, 21 September 2024 at 3:07 PM
I was wandering if it is possible for walk designer to do stairs, or to make a walk path do stairs, or something along those lines without having to actually do the walk frame by frame? just curious if its possible?
Teyon ( ) posted Wed, 07 March 2007 at 11:21 PM
Check your library. There should be one in there already.
lesbentley ( ) posted Thu, 08 March 2007 at 6:22 PM
Don't know about P7, but I don't think there is any way in earlier versions to do walking up stairs.
Teyon ( ) posted Thu, 08 March 2007 at 6:35 PM
It's not in the Walk Designer itself and that's my bad for not being clear.
In the Pose library, there's a set of poses for stair climbing. Mixing them up can give you a solid jumping off point for an animation. You'd only need to go back and and do some tweaking here and there.
freefall565 ( ) posted Fri, 09 March 2007 at 11:41 AM
Thanx lesbentley, I actually am working in poser 6, so if you happen across how it is done, please let me know.
freefall565 ( ) posted Fri, 09 March 2007 at 11:42 AM
Thank you teyon, I'll give it a try and see if I can work it out.
