Check for the XFrog Billboard plants for Poser by greenworks, Ghost. He's got some in there for England.
Hugz from Phoenix, USA
Victoria
There is one tree that is looking good at RDNA but I am looking for a few more. I looked up Sherwood in google but only found birch and oak and I was wondering if others knew of more since I had never been. Thanks for the fantasy forest idea nickedshield ... I don' go there very much anymore and missed those.
Attached Link: http://www.vanishingpoint.biz/productdetail.asp?ProductID=241
Try these by SyaPed. They contain the type of British trees mentioned and the pack has both models for closes up, low poly oak and maple props for mid distance and alpha plane versions for backgrounds.Pinky - you left the lens cap of your mind on again.
Attached Link: http://sourceforge.net/projects/arbaro
> Quote - no, wait - I just recalled arbaro, a free java tree-generator app that's pretty good IMVHO.Link for you.
Miss Nancy / nruddock:
What is that app please? (arbaro) as there doesn't seem to be any info about it, from the renders there it looks like it is a 3D tree generator and you can render them in different apps but i was curious as to what format / file type it exports as, as i was hoping it might import into Vue (maybe as .3ds for including as part of an eco-system)
also is it a stand alone or plugin for something else?, is it freeeeeeeeee? and is it stable?
just a bit worried about it as any time anything has ever gone wrong with my computer it has usually had something to do with java things (don't know about java stuff)
Thanks for anymore info about it.
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2550650&ebot_calc_page#message_2550650
vinnie, it's free, stable, easy to use, stand-alone, starts from command line, saves wavefront.obj files, povray files and dxf. I used it in OS X, but I'm guessing there is a command-line interface in windows, which also uses java. the arbaro readme explains how to use it in some detail. it can make trees nearly as good as treepro IMVHO, which is somewhat more expensive, assuming they still sell it."Forest" in medieval england wasn't dense woodland. It was land managed for hunting, primarily deer. There were villages and farmland in the forst area, but Forest Law applied. Pretty much, you'd have the normal English trees: oak, ash, elm, birch, and a lot of others. The deer would probably lead to fairly open woodland that was short of ground cover. The Woodland Playsets come close to that look. Modern Sherwood Forest is mostly on lighter, sandy, soil, which has some effect on which trees thrive. Places like the Dukeries, to the north, are relatively modern managed landscapes, of the sort associated with Capability Brown.
Quote - Thanks for the tree list Antonia Tiger .... I am trying to do a good, accurate render for a friend.
The Park tree at RDNA looks good but the old wood ones aren't as good as I need since it will be a bunch of closeups.
here is a close up of the old wood tree I used, just for referance..
http://www.renderosity.com/mod/gallery/media/folder_138/file_1370382.jpg
I am doing a dense English forest ala Sherwood Forest and I need advice on trees and stuff. A lot of the poser trees out there are too small or not that great. Bryce trees have no way to make big/old trees (that I know of) and I don't meet the requirements for Vue. So, does anyone know of something to make a decent forest scene? Some extra programs are PC only so that could be an issue since I have a Mac. Thanks
