Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Thanks Marque. I had the same question about the brows. I was using the transparency maps so I figured that part out. But I was still getting an outline on the brows, about to drive me nuts, so went and changed the object color from white to a skin tone and that seemed to fix it. In the material settings there were 2 brow objects, one was white and the other was brown. I changed the object colors on both of them. Did I do that correctly? Arleen
There are a lot of things worse than dying, being afraid all the time would be one.
ringbearer, There is a little trick I learned, if you want to make sure it's the same color as the head or body, go to the head texture and add it color to custom colors, there is a button there for that. That way you don't have to mess around with writing down the numbers for that color. Then you will have the exact color that you need to get rid of the eyebrows. Marque
And remember, on any transmap, the highlights must be completely black. Anything less than total black and there will be ghosting. Time spent learning to use the UpperEyeBrows properly will pay off. The effect is much better than the painted Eyebrows. I replace the Eyebrow texture with a skin cloning on all Head textures and only use the UpperEyeBrows. Complaining about the Upperbrows and only using the Eyebrows is a bit like hitching a horse to your new auto and cursing the manufacturer for puting that heavy block of stuff under the hatch at the front.
Thanks Marque for the tip on the custom color. That will help a lot. Ghostofmacbeth-Which texture should I load for the transparency? I'll check that again. PERVERS-I'm gonna try your tip also. Thanks for all of your help. Arleen
Jaager-You posted while I was typing so didn't see your reply. Thanks for your help. I think these are all good tips and they are much appreciated. I will try your tip out also. Thanks again! Arleen
The idea of the transmap for the lashes is pretty straight forward. It gives the impression that eyebrow hairs are protruding out of the head. Like they do on us humans...:) This funcion was there on V1 but nobody seemed to use it. Personally i wouldn't do without it now. If you have 'Michael' it does the same thing.
I have downloaded the vicky 2 model with the high res textures but whats with the super bushy thick disgusting eyebrows ?? I changed the eyebrow textures to the hires ones, as well as the bump maps but I just cant get them nice and thin ? Anybody know what I am doing wrong ? I have enclosed an image to show you what I mean.
