Tue, Feb 11, 2:09 PM CST
Subject: Trouble with tits
moldie ( ) posted Sat, 12 May 2001 at 2:43 AM ยท edited Tue, 11 February 2025 at 11:43 AM
This is the normal Zygote Victoria with no morph targets or anything. This texture is fine, too, with none of the glitches you see here. I have the exact same trouble with every texture. What's going on?
JeffH ( ) posted Sat, 12 May 2001 at 2:46 AM
Use anti-alias in the render options.
RealitysPoison ( ) posted Sat, 12 May 2001 at 8:15 AM
Or do you mean where the texture 'slid' at the nipple? Was this rendered? I have had that problem before where the nipple wants to run across the chest, but that was only when I was working. When I rendered the scene, it placed just fine.
Jim Burton ( ) posted Sat, 12 May 2001 at 9:09 AM
Check the nipple material, if not set to white it will conflict with the map, especially if the map isn't regestered well in that area.
moldie ( ) posted Sat, 12 May 2001 at 11:42 AM
Its rendered, and set to white. I'm still haveving the problem.
black-canary ( ) posted Sat, 12 May 2001 at 5:50 PM
there's a pretty distinct ring around the right areola...it sure looks like it's not set to white. But the texture also may have a problem with the nipple placement on the right side. Is this a custom texture?
moldie ( ) posted Sat, 12 May 2001 at 9:09 PM
Yes, but I chose it to show to you guys because areolas were rounder than most of them. As I said, I am having trouble with every texture, including the original Millwoman texture Victoria came with.
