Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 04 8:39 am)
And be sure to select 'Spawn Morph' rather than 'Apply' once you're finished in the Face Room.
For some reason hitting 'Apply' moves the head (but not the eyes I believe).
Aside from that, have fun...I know I have been!
If we can hit that bullseye, the rest of the dominos will fall like a house of cards...checkmate!
Hi, I'm having the same problem. I placed all the face room files exactly where they should go, but I am getting "figure is not supported" message anyway. I even made sure I used Apollo2007 cr2 and not Cole. Strange.... I'm running Poser 6 on a MacMini OSX4, no external runtimes. If you ignore "figure is not supported" you see James' head. If you continue with James' face and hit "apply", Apollo will have James' head on his body instead (which is interesting but not the desired results. ^^;;;). You can't hit "spawn morph target" because the vertices are different (James is not Apollo). bB
Open the file "KnownFaceRoomHeads.xml" and verify that you see the line:
If it's not there then you didn't install the files from anton's zip correctly because he has the apollo definition in the knownfaceroom.xml file that he distributed.
Again, and I can't stress enough for anyone else installing the files, they must go in you Installed Poser runtime and not external ones.
It only recognises them when you load them fresh from CR2! I've run into this little quirk in both Poser 6 and Poser 7! So if you're trying to open a previously saved PZ3 that you really liked and taking the figure to the faceroom, you'll get the same figure not known message! Annoying huh?
Quote - Finally able to get my hands on the new apollo, however, i cant seem to get the face room module to work. It continually tells me that this figure is not supported. Where, precisely do i put the module for it to work?
Thanks for any help.
The module is for Poser 6 and Poser 7. However it does seem there may be no luck for some woth Poser6 for Mac.
Faceroom module for Poser7 mac users is fine. Unfortunate but at least it is the older version.
If you do not have Poser6 mac, then just make sure you install the folder as it is nested.
Cheers
-Anton, creator of Apollo Maximus
"Conviction without truth is denial; Denial in the
face of truth is concealment."
