Sun, Jan 26, 5:42 PM CST
Subject: Aiko's nipples :-)
sirenia ( ) posted Fri, 23 March 2007 at 3:38 PM · edited Sun, 26 January 2025 at 5:30 PM
Hope i don't start some weird thread here but i have to ask... :biggrin: Is it possible to HIDE her nipples e.g. for when you use a second skin texture on her ? Yes you can 'dial them out' but to me it's not the same as some injection morph that would do the trick. Maybe there is a morph out there that i do not know of, or someone could make such a morph ? Thanks Wim
Society failed to tolerate me...
... and i have failed to tolerate society
pjz99 ( ) posted Fri, 23 March 2007 at 5:01 PM · edited Fri, 23 March 2007 at 5:06 PM
Hide as in hide the texture?  You could change the material to use another part of the skin, adjust UV a bit.
Hide the geometry as in make it smooth against the contour of the breast?  It would be easy enough to make yourself really, just make a morph target of your final, desired, nipple-endowed shape, and go to Object -> Spawn Morph Target with that body part selected, and THEN dial out all the breast adjustments, while dialing up your new morph target to 1.
Since Aiko has each breast on its (her?) own joint, this is a bit fiddly because you end up with two morph sliders, but how often are you going to use it?
My Freebies
pjz99 ( ) posted Fri, 23 March 2007 at 5:06 PM
My Freebies
Xena ( ) posted Fri, 23 March 2007 at 6:02 PM
Aiko 3 loads without nipples dialed in. So, don't dial them in and you won't have to worry about them. There is a Nipples morph on the Body dial to load the nipples - so only one dial is needed, not two.
Also, her breasts aren't separate groups, the breasts are included in the collar groups (left and right).
pjz99 ( ) posted Fri, 23 March 2007 at 7:16 PM
Sorry, that's what I meant to say - "Collar".
My Freebies
sirenia ( ) posted Sat, 24 March 2007 at 6:50 AM
Actually i forgot to mention that i scaled down her breast size. And as a result the 'Areola' and 'nipple' are starting to show. With some tweaking of the dials i can get smooth breasts, however what i'm after is smooth breasts without the polygons in them from the areola's and the nipple's. Thanks
sirenia ( ) posted Sat, 24 March 2007 at 6:53 AM
After some dialing... still visible :glare:
modus0 ( ) posted Sat, 24 March 2007 at 11:54 AM
That looks like something to do with the texture to me, have you tried looking at the texture with her in her default state?
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
sirenia ( ) posted Sat, 24 March 2007 at 12:40 PM
I tried without the texture, and after that also with another texture but the problem aria remained the same :sad: I guess it has something to do with the polygons on the figure... :unsure: Too bad, but nonetheless fixable in Photoshop i guess.
Xena ( ) posted Sat, 24 March 2007 at 6:24 PM
I'm not sure I understand your problem. I've attached an image of Aiko 3 with smaller boobs and there is no nipple to be seen at all.
sirenia ( ) posted Sun, 25 March 2007 at 9:24 AM
Here's a pic without the textures so you can see more clearly what i mean. This is Aiko with the 'Thumbelina' morph and scaled down boobs. There clearly shows a dent in the geometry !!
modus0 ( ) posted Sun, 25 March 2007 at 4:03 PM · edited Sun, 25 March 2007 at 4:05 PM
That looks like a problem with the character morph as I didn't see anything like that last night with just the basic breast morphs.
Xena ( ) posted Sun, 25 March 2007 at 6:22 PM
Yeah, I'd have to agree with Modus. With Aiko 3's morphs there's no dent in the nipple area.
Are you dialing this Thumbelina morph past 1? Are you using any other morphs with it?
sirenia ( ) posted Mon, 26 March 2007 at 11:40 AM
Hi, I did some tests with a second Aiko loaded in the same scene as 'Thumbelina' and gave this one the same breast morphs as those from Thumbelina. Indeed there are no dents in the new figure, but then i looked a bit further at some of the morphs from Thumbelina... The Thumbelina figure has also some other morphs dialed in e.g. Muscular (0.272) and Young (0.452) and this is what's causing the problem altogether ! Check it out with standard Aiko with these morphs : - Muscular 0.272 - Young 0.452 - BreastSize 1 0.772 - BreastSize 3 -0.628 It's all within the limits of the +1 -1 "morphlimits" but from this point on you can detect dents in some parts of the geometry.
