Hide as in hide the texture? You could change the material to use another part of the skin, adjust UV a bit.
Hide the geometry as in make it smooth against the contour of the breast? It would be easy enough to make yourself really, just make a morph target of your final, desired, nipple-endowed shape, and go to Object -> Spawn Morph Target with that body part selected, and THEN dial out all the breast adjustments, while dialing up your new morph target to 1.
Since Aiko has each breast on its (her?) own joint, this is a bit fiddly because you end up with two morph sliders, but how often are you going to use it?
Aiko 3 loads without nipples dialed in. So, don't dial them in and you won't have to worry about them. There is a Nipples morph on the Body dial to load the nipples - so only one dial is needed, not two.
Also, her breasts aren't separate groups, the breasts are included in the collar groups (left and right).
Society failed to tolerate me...
... and i have failed to tolerate society
I tried without the texture, and after that also with another texture but the problem aria remained the same :sad: I guess it has something to do with the polygons on the figure... :unsure: Too bad, but nonetheless fixable in Photoshop i guess.
Hi, I did some tests with a second Aiko loaded in the same scene as 'Thumbelina' and gave this one the same breast morphs as those from Thumbelina. Indeed there are no dents in the new figure, but then i looked a bit further at some of the morphs from Thumbelina... The Thumbelina figure has also some other morphs dialed in e.g. Muscular (0.272) and Young (0.452) and this is what's causing the problem altogether ! Check it out with standard Aiko with these morphs : - Muscular 0.272 - Young 0.452 - BreastSize 1 0.772 - BreastSize 3 -0.628 It's all within the limits of the +1 -1 "morphlimits" but from this point on you can detect dents in some parts of the geometry.
Hope i don't start some weird thread here but i have to ask... :biggrin: Is it possible to HIDE her nipples e.g. for when you use a second skin texture on her ? Yes you can 'dial them out' but to me it's not the same as some injection morph that would do the trick. Maybe there is a morph out there that i do not know of, or someone could make such a morph ? Thanks Wim
