Go get edit pad pro. It rocks. You can do endless thinsg with it links sorting, alphabetical ordering, deleteling duplicate lines or text, tec.
It can also open much larger documents that wordpad.
-Anton, creator of Apollo Maximus
"Conviction without truth is denial; Denial in the
face of truth is concealment."
i've tried tons, but i've stuck with www.emeditor.com for -everything-, cr2/pz2 editing, web work (html/css/php, etc ). going on 3 or 4 years now i think.
UltraEdit here - and that Wordfile was from me. :)
Since then, I've found Dimension3D's PoserEd to be much better at Poser file editing - or just finding stuff in these massive files.
I'll have to try EditPad Lite as well.
If you ever need to do straight Unicode editing, there is only one choice: SC UniPad. You will pay for it though ($199).
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
I actually use VIM more often than not - it'll load huge files without choking and once you get the hang of it it's damn fast
My Freebies
Buy stuff on RedBubble
I'm not into typing a lot, so normally wordpad is sufficient for me. But on my laptop I don't have wordpad, not even hidden (I did search).
When I enter wordpad replacement in Google, I'm overwhelmed wirth an app called Jarte, but the interface looks not really trustworthy.
So what would you recommend to replace wordpad? (evt notepad incl.)
thanks.
