Wed, Dec 4, 2:16 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 12:42 pm)
Subject: P6 textures while rendering
tsunami987 ( ) posted Tue, 10 April 2007 at 9:30 PM · edited Wed, 04 December 2024 at 2:06 PM
Been having a problem lately.  Load a figure, clothes, mats and all the textures are there, when i render i get a window asking to locate the textures that material room already has located.  I just have to hit cancel and it renders fine but does anyone know how I can stop the annoying window from asking.
Francemi ( ) posted Wed, 11 April 2007 at 5:43 AM
Did you reboot your computer lately? Sometimes Poser gets confused like it has Alzheimer!
France, Proud Owner of
KCTC Freebies
BeyondVR ( ) posted Wed, 11 April 2007 at 1:33 PM
Poser will always ask about missing files when you load a PZ3, but I had it ask at render time just a couple of days ago.
I had changed a material, but had used an older file by mistake.  It loaded fine, but asked for a deleted image on rendering.  It was a node mask I had decided not to use, so it seems Poser doesn't actually check to see if the images are there when you load a mat in the mareials room.
That's the only time it gave that message when rendering.
John
tsunami987 ( ) posted Thu, 12 April 2007 at 5:43 AM
Thanks for your response but no, everything is fine with all the textures, i hit cancel on the window and it still renders fine and even if i direct it the correct file when it asks it will still ask again for the files if i re-render the same image, its not a big problem just annoying
Francemi ( ) posted Thu, 12 April 2007 at 6:58 AM
Sometimes what happens is that you replace a material in material room and leave the little box from the last material there (image map, color map, etc.). Well Poser still tries to read this old material.
KCTC Freebies
tsunami987 ( ) posted Fri, 13 April 2007 at 12:04 AM
that i would understand but it asks for each and every individual texture one after another associated with the scene
pjz99 ( ) posted Fri, 13 April 2007 at 12:38 AM
That happens to me sometimes as well, and I just drill to where the particular texture file is (sometimes have to search a bit) and it's OK with just asking me one time.  I hadn't thought to trust hitting Cancel there though.
My Freebies
Francemi ( ) posted Fri, 13 April 2007 at 7:45 AM
Do you have the same problem with ALL the figures or props? If it's only one, open the file in WordPad (or another text editor) and check the shading nodes. I noticed that many times Poser will keep the old texture filename in the shader tree when you change the texture map.
Example: when I saved this prop I chose the texture map "autel_fr01.jpg". After it was saved in the libraries I changed my mind and applied the texture map "autelbody_fr01.jpg". Look in the code below and you'll see that the top part shows the new texture map but Poser kept the old texture map in the shader tree. If I was to load this file in Poser like this Poser would ask for the old texture map. And if I happened to change all texture maps for this prop it would ask for all of them. ;o(
material top_panel
KdColor 1 1 1 1
KaColor 0 0 0 0
KsColor 0 0 0 1
TextureColor 1 1 1 1
NsExponent 10
tMin 0
tMax 0
tExpo 0
bumpStrength 1
ksIgnoreTexture 0
reflectThruLights 1
reflectThruKd 0
textureMap ":Runtime:textures:Francemi:Autel:autelbody_fr01.jpg"
0 0
bumpMap NO_MAP
reflectionMap NO_MAP
transparencyMap NO_MAP
ReflectionColor 1 1 1 1
reflectionStrength 1
shaderTree
node "image_map" "Image_Map"
name "Image_Map_1"
pos 237 26
nodeInput "Image_Source"
name "Image_Source"
value 0 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ":Runtime:textures:Francemi:Autel:autel_fr01.jpg"
KCTC Freebies
tsunami987 ( ) posted Thu, 26 April 2007 at 9:19 PM
Thanks for your responses and yes it was with every different figure  not just one but I just got a new computer and havent installed everything yet so hopefully it wont reappear
