Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 6:38 pm)
Quote - It is rather aggravating to try and get one meshes vertices 1 mm from another meshes vertices especially doing 1 Vertices at a time.
:lol: That one was good...
You can do it 2 ways: Like tekmonk said with an shrink-wrap tool or by copying and moving.
I don't know C4D... shrink-wrap can be called differently. It is a tool to make one plane or mesh fit to the shape of another mesh. Similar to the way dynamic clothes fiting to the bodyshape in Poser or Maya.
If you copy the needed parts of the mesh without changing their location and move them away you get a similar result. That might work nice for a shirt but can be much work for gloves for example.
You should have an option to move an object by entering numbers for its new location otherwise it'll be hard to get exactly 1mm.
Here is another option if you're interested - 2nd Skin by Dimension3D. When completed, the "2nd skin" is a conforming figure that will accept all the morphs from the original figure.
http://market.renderosity.com/mod/bcs/index.php?ViewProduct=36265
~ Meow ~
You might find some interesting info in the 3D modelling forum, this thread in particular: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2668504&page=6
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
Here are some examples of Line Fit used. In the modeling of these clothes. That is just part of the process I use but It is how I start most of my clothes.
You should be able to extrude a mesh a short distance above the model, provided that it is in a separate layer. You can make a row of quads, edge select and extrude your way around the object. If you need to adjust the mesh, just pull the points.
Quote - a little OT, but is there a shrinking tool for Shade?
you can shrink wrap a line to a mesh with the Tools>Modify>LineFit...
you select the line or lines you wish to shrink (or grow) and the polygon mesh or meshes you want it to wrap and then select this command. A dialog will pop up for you to enter distance and direction.
To the best of my knowledge there is not a way to shrink wrap a mesh to a mesh.
My Homepage - Free stuff and Galleries
I am a experienced modeler in C4D my Skull avatar is my creation.
I am not experienced at modeling cloths off of another mesh in Poser
If A3 was mine I would just split off the A3 polygons to make the T-Shirt with.
But it is not so I can not.
So I took one of my females meshes and cut out a t-shirt from her polygons for a A3 T-Shirt.
The problem is getting the mesh 1mm from all of A3's polygons is a real pain.
The vertices are to high or there to low etc etc.
Tell me there is a better way, and what that better way might be ?
Thanks
RorrKonn
http://www.Atomic-3D.com
