Tue, Feb 4, 4:29 AM CST
Subject: Has anyone else ever had this "Problem"???
FutureFantasyDesign ( ) posted Mon, 07 May 2007 at 2:20 AM · edited Tue, 04 February 2025 at 4:21 AM
I keep getting this pop up on occassion...makes no sense and I don't know how to fix it. Last time I reinstalled poser and it was ok...til now! I am getting a nagging feeling it is a setting...but I don't know what. Anyone? The last time it happened was with rebelmommy's Evalyn. Never happens on a V3. It renders out fine, but you can't see the figure after you apply the base texture. Is this a glitch with V4's?
ThanX!
Ariana
Is there water in your future or is it being shipped away to be resold to you?
Water, the ultimate weapon...
www.futurefantasydesign.com
surreality ( ) posted Mon, 07 May 2007 at 2:30 AM
Wish I knew what to tell you! Seriously, I'm baffled. It's something I've seen on a texture (though oddly, not that one) once, and it had my fan running wildly all the while it was in that mode, but I can't recall off the top of my head what it was precisely.
-D
It's all fun and games until someone loses an eye texture.
FutureFantasyDesign ( ) posted Mon, 07 May 2007 at 2:37 AM
LOL! I just was writting you there! You wait I will conquer this if it drives me nuts! I want to use her so bad!!!!! As much as I love Marai, I know Dahlia will be used just as often! :) LOL! I may call Colin at e-frontier tomorrow...probably another P7 glitch!
HuggerZ!
Ariana
surreality ( ) posted Mon, 07 May 2007 at 2:42 AM
laugh Email and forum tag. Gotta love it.
-D
Acadia ( ) posted Mon, 07 May 2007 at 3:28 AM
Check your document settings.
Also, try going to the material room and moving the transparency up or down and putting it back to where it was.  When things go invisible in Poser 6, the transparency trick sometimes helps.
4blueyes ( ) posted Mon, 07 May 2007 at 3:59 AM
It quite looks like the preview cannot handle the shaders on the characters appplied, I can be wrong though :). Does it happen randomly with random characters or with the same characters all the time? Try to switch between OpenGL and SreeD preview modes and check if it changes anything. Michal 4blueyes
pjz99 ( ) posted Mon, 07 May 2007 at 4:39 AM
If you see something like that, where Preview shows strangely but render works fine, there is a good chance it is an OpenGL problem like 4blueyes suggests.  You may want to download and install some updated version of your graphics card driver, which should include OpenGL drivers.
My Freebies
FutureFantasyDesign ( ) posted Mon, 07 May 2007 at 10:53 AM
ThanX to everyones input! -I am using Poser 7 and I do use open GL....This happens randomly. It happened 3 times with rebelmommy's Evalyn, and I did a reinstall and she loaded fine after that. But it must be the settings on it somewhere I run a mid range graphics card from ATI and i just updated it some 3 months back. I will try it....cause I only encounter this with V4s! Never on a V3. So you would think it would be across the board. I will try all advice and report back my results, I am also going to cal e-frontier, as this seems to be a P7 problem for me.
ThanX!!!!!
Ariana
FutureFantasyDesign ( ) posted Mon, 07 May 2007 at 4:44 PM
OK....I wonder, is there a way to delete shaders from an irridescent that over reflects? I am working in this now. Hmmmmm....Oh btw, I was right it was a p7 glitch. I fixed it but you have to do it each time. You uncheck enable hardware. And lower the preview texture settings.
HuggerZ!
Ariana
Angelouscuitry ( ) posted Mon, 07 May 2007 at 5:34 PM
Check what the Display > Document, Figure, and Element Style settings are.  They should each have Texture Shaded checked.
If not post a screenshot of the material room for the figure, and then for the lights.
FutureFantasyDesign ( ) posted Mon, 07 May 2007 at 5:57 PM
ThanX Angelouscuitry! Give me a few minutes (*more actually) I have to do the Wife thing! LOL! Be back shortly!
Ariana
Angelouscuitry ( ) posted Mon, 07 May 2007 at 7:24 PM
slinger ( ) posted Tue, 08 May 2007 at 12:35 PM
Take a look at your Render/Preview settings, and try unchecking "Enable Hardware Shading" if it's ticked.
The liver is evil - It must be punished.
FutureFantasyDesign ( ) posted Tue, 08 May 2007 at 12:56 PM
*see above...I already got that! ThanX! I will be back shortly, car issue!
Ariana
pjz99 ( ) posted Tue, 08 May 2007 at 5:02 PM
Well, it may be a Poser 7 bug, but what that "should" mean is that your video card's OpenGL driver is taking the graphics stuff from Poser and trying to display it, but failing.  Disabling Hardware Shading is not really an ideal fix, as hardware generally quite a bit faster and higher quality than the software shading guts - although if it's what you have to do  to make it work...
Had you tried updating graphics drivers?  That may help you.
My Freebies
Angelouscuitry ( ) posted Tue, 08 May 2007 at 5:14 PM
:blushing:
FutureFantasyDesign ( ) posted Wed, 09 May 2007 at 12:19 AM
I know my day went to hell! :P I got the car towed and then had to deal with a printer and a show co-ordinator...I am so over stretched! Let's give this a try tomorrow? OK? Sorry i am beat!
HuggerZ!
Ariana
