Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
We've always been able to export terrain meshes, but with Bryce 6.1 you can now export a boolean conversion, that is if you take a positive and a negative and boolean them, you will get a 'convert' icon [c] on the icon column. You can then export this as an obj, dxf, etc.......
Hope this helps.
You're welcome!
I can assure you that I have tested this particular bit of Bryce-candy extensively. It works just fine!
My only gripe is that when you hit the [c] icon, the group keeps its original bounding box size. However, that is corrected when you re-import the item into Bryce.
As I said earlier, using the [c] icon still leaves the original bounding boxes and that can cause problems. Better to export and then import BACK INTO Bryce which means you get a 'clean' object. This is wholly in keeping with the sanctity of the Blessed App. ;-)
Quote - As I said earlier, using the [c] icon still leaves the original bounding boxes and that can cause problems. Better to export and then import BACK INTO Bryce which means you get a 'clean' object. This is wholly in keeping with the sanctity of the Blessed App. ;-)
Sounds like a cover-up to me.
I think TheBryster has secretly been using heretical apps. but doesn't want to be condemned by his fellow cardinals as a heretic. :lol:
Friends don't let friends use booleans.
*Sounds like a cover-up to me.
*That's slander!
why would you export a blessed boolean construction out of Bryce in the 1st place, except...ahem...to use it in another program?..;) Inquiring minds want to know...I'll make room on the comfy chair...prepare the soft cushions...;)
Hehe, I do it from time to time now. That Japanese lantern (http://www.renderosity.com/mod/gallery/index.php?image_id=1374731&member) was a Bryce 5 project, converted in Bryce 6. I've been wanting to make this into a freebie for a while, so I use it to make sure it behaves right before making it available.
But you're right.. it's handy to have it exportable for other apps to alter it. The only two other apps I use to enhance Bryce is in terms of exporting from, is the Ivy Generator and then CB Modeler Pro.
I really like that Ivy Generator.
hello,
i'm thinking to buy bryce.
but can we export all meshes,all kind of objects in OBJ ?
thank you for your precious help
