I'm not seeing your image...
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
You could try using The Tailor, which is found at Daz and adding some of the figure's morphs to the outfit, that might help.
You might also try magnets.
And if you have Wardrobe Wizard by PhilC you should be able to get it to fit the figure without much of a problem.
say." - Ghandi
I can see the image now. Odd.
Anyway, I would use magnets to fix this. Here is 3dWizard's tutorial on using magnets:
http://www.planet-3d.com/tutorials/basicmags/
The best tutorial I ever found for mags was by Traveler, but it was hosted on bbay and doesn't seem to be there anymore...
"you are terrifying
Shire
Attached Link: How to make matching JCM morphs in your clothing, a Tutorial
What figure is that? If she has JCMs (Joint Controlled Morphs) as V3 and V4 do, maybe others, you will need to replicate them in the clothing; this would affect V3's collar bends for example. I'm at work so I daren't dwell on the picture too long. :closedeyes: JCMs are a pain. I've linked to a tutorial at PoserPros if you need one.Yep, I agree with BOTH Nickedsheild and englisbob, you'll robably need a combination of adjusting JPs and the addition of a few JCMs to get very tight conforming type clothing to work without poke thru.
best way to approach this is to note the locations that need to be fine tuned, and exactly which movement or combination of movements cause the problem. Then use the Joint Control panel to see if a tweak to the JPs can help. Remember to double check the movemnt after making any JP changes, since you can make it better for one bend and worse for another!
If that doesn;t work you'll have to create morph moving the clothing into the desired position then turn it into a JCM ( if you want it to operate automatically, nothing wrong with leaving it as a manual morph if you don;t mind twisting the dials to suit.). The tut englishbob refers to is very good.
mike
Thanks English Bob and trav, the figure is Sydney from P7. I loaded one of the other clothing models that came with P7 to look at the joint settings, and got it a lot closer, I tried some sitting and laying poses on it, and they worked a lot better, there were still a couple of spots I want to get better. I`ll go look at the tutorial a little later when I have some more time.
