Sat, Jan 11, 7:16 AM CST
Subject: Close but no cigar----how can I get this to conform better ?
sekhet ( ) posted Thu, 31 May 2007 at 4:09 PM · edited Sat, 11 January 2025 at 7:11 AM
Like the subject says, any hints on what I need to do to get this to conform more like it should? Do I need to group it differently, or just fiddle with the joint parameters some more.  Any tutorial out there on making conforming clothing? Sorry if the image is too small the big one was too big to upload.
KarenJ ( ) posted Thu, 31 May 2007 at 4:11 PM
I'm not seeing your image...
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
thefixer ( ) posted Thu, 31 May 2007 at 4:22 PM
Karen, you need to "open your eyes"
Injustice will be avenged.
Cofiwch Dryweryn.
thefixer ( ) posted Thu, 31 May 2007 at 4:23 PM
Huh! What gives!!   It's gone now, it was there before!!!  Weird!!  Let me check if my eyes are open!!!
Cofiwch Dryweryn.
thefixer ( ) posted Thu, 31 May 2007 at 4:24 PM · edited Thu, 31 May 2007 at 4:24 PM
Now it's back!!  Cue Twilight zone muzak!!!!
I'm off to bed!!!
Cofiwch Dryweryn.
Acadia ( ) posted Thu, 31 May 2007 at 4:27 PM
You could try using The Tailor, which is found at Daz and adding some of the figure's morphs to the outfit, that might help.
You might also try magnets.
And if you have Wardrobe Wizard by PhilC you should be able to get it to fit the figure without much of a problem.
KarenJ ( ) posted Thu, 31 May 2007 at 4:32 PM
I can see the image now. Odd.
Anyway, I would use magnets to fix this. Here is 3dWizard's tutorial on using magnets:
http://www.planet-3d.com/tutorials/basicmags/
The best tutorial I ever found for mags was by Traveler, but it was hosted on bbay and doesn't seem to be there anymore...
"you are terrifying
sekhet ( ) posted Thu, 31 May 2007 at 6:33 PM
Thanks for the suggestions, but this is my 1st attempt at modeling "clothes" for Poser if you can call it that. I ran it through the set-up room in P7 and it works pretty well so far, but I wanted to try and get it to pose with the character better.
nickedshield ( ) posted Thu, 31 May 2007 at 8:22 PM
If you want it to pose better as you say, you were right. You will have to fiddle with Jps until they are to your liking.
EnglishBob ( ) posted Fri, 01 June 2007 at 6:21 AM
Attached Link: How to make matching JCM morphs in your clothing, a Tutorial
What figure is that? If she has JCMs (Joint Controlled Morphs) as V3 and V4 do, maybe others, you will need to replicate them in the clothing; this would affect V3's collar bends for example. I'm at work so I daren't dwell on the picture too long. :closedeyes: JCMs are a pain. I've linked to a tutorial at PoserPros if you need one.
Letterworks ( ) posted Fri, 01 June 2007 at 6:56 AM
Yep, I agree with BOTH Nickedsheild and englisbob, you'll robably need a combination of adjusting JPs and the addition of a few JCMs to get very tight conforming type clothing to work without poke thru.
best way to approach this is to note the locations that need to be fine tuned, and exactly which movement or combination of movements cause the problem. Then use the Joint Control panel to see if a tweak to the JPs can help. Remember to double check the movemnt after making any JP changes, since you can make it better for one bend and worse for another!
If that doesn;t work you'll have to create morph moving the clothing into the desired position then turn it into a JCM ( if you want it to operate automatically, nothing wrong with leaving it as a manual morph if you don;t mind twisting the dials to suit.). The tut englishbob refers to is very good.
mike
sekhet ( ) posted Fri, 01 June 2007 at 10:26 AM
Thanks English Bob and trav, the figure is Sydney from P7. I loaded one of the other clothing models that came with P7 to look at the joint settings, and got it a lot closer, I tried some sitting and laying poses on it, and they worked a lot better, there were still a couple of spots I want to get better.  I`ll go look at the tutorial a little later when I have some more time.
