Mon, Nov 11, 2:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 11 2:16 pm)
Subject: Self Illuminated materials??
alphauser51 ( ) posted Sat, 02 June 2007 at 10:41 AM · edited Mon, 11 November 2024 at 2:46 PM
How do you make a material self illuminated in Poser?
In 3D Max this would be simple, but I cant figure how how to do this
in Poser and there is nothing in the manual or on the net.
Any help appreciated.
wheatpenny ( ) posted Sat, 02 June 2007 at 11:01 AM
Site Admin
For that you would need Luminosity, which AFAIK Poser doesn't have
the closest equivalent is to make the object translucent and put a poing light inside it.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Victoria_Lee ( ) posted Sat, 02 June 2007 at 11:16 AM
Try this thread.  I've been playing with it.  It's not something that happens right away but with some experimentation it should happen.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2217752
Hugz from Phoenix, USA
Victoria
stewer ( ) posted Sat, 02 June 2007 at 1:29 PM
Just set the material's ambient_color and ambient_value.
alphauser51 ( ) posted Sat, 02 June 2007 at 2:09 PM
Im trying to  illuminte  an  video clip mapped to  an object.
To simulate the glow of a tv monitor with an animated video.
odeathoflife ( ) posted Sat, 02 June 2007 at 3:48 PM
You are going to have to cheat by using a spot light, and maybe depending on the situation, some volumetrics.
stwerer is right though ( as always LOL) you will have to boost the objects abients.
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Acadia ( ) posted Sat, 02 June 2007 at 4:34 PM
Attached Link: http://www.runtimedna.com/mod/forum/messages.php?ShowMessage=277007
If anyone can help, it's bagginsbill.  Have a look at that thread. It might help you. If not you can try posting to ask if it's possible for your project.
Angelouscuitry ( ) posted Sat, 02 June 2007 at 10:24 PM
Attached Link: glow effect in poser help!
See my post from Thu, May 17, 2007 5:17 pm for more ideas.
bagginsbill ( ) posted Sun, 03 June 2007 at 7:11 AM
Confusion alert.
Self-illuminating? You mean you want an object to be bright even if there are no lights in the scene, right? No problem - use the ambient as people said. For a movie or image map, you don't even have to do that. Plug it straight into the Alternate_Diffuse input. Make sure you turn off Diffuse_Value and Specular_Value, unless you want to simulate a glass surface on top of the image - then use specular as well.
Illuminating other things? Its best to set up one or more lights (spot or point) parented to the object. A point light just in front of the middle of a TV screen works pretty well Use ray-traced shadows on it. You could use spot lights, but they only spread up to 160 degrees - so I use two or more if I need a lot of nearby objects lit, to get those last 20 degrees covered.
Illuminated BY other things? That would be the Gather node, but it is really bad - produces grainy results or is excruciatingly slow.
Angelouscuitry ( ) posted Tue, 19 June 2007 at 10:08 AM
I'd been thinking the Gather was grainy, thanks, I'll be waiting for especially good news!
:tongue2:
