Mon, Feb 10, 2:24 PM CST
Subject: radiant jaguar hair from DAZ looks terrible rendered in vue
estherau ( ) posted Tue, 05 June 2007 at 11:48 PM · edited Mon, 10 February 2025 at 2:22 PM
Has anyone else got this hair? How do you make it look better? I tried changing the highlight colour from black to whitish but this didn't help. Love esther
MY ONLINE COMIC IS NOW LIVE
vincebagna ( ) posted Wed, 06 June 2007 at 2:19 AM
Could you post a screenshot so we could see?
And have you try to increase your AA settings? Sometimes it helps.
estherau ( ) posted Wed, 06 June 2007 at 2:30 AM
Hi, no I didn't try and increase AA per se, but I did increase the general render qual setting. I think this one is broadcast, but I did try superior and the problem still exists. what AA setting do you suggest? Love esther PS this is just a standard atmosphere too. ie no AO or GI or anything
estherau ( ) posted Wed, 06 June 2007 at 2:35 AM
In the preview image of poser 7, without even rendering, the hair looks excellent. what gives?
vincebagna ( ) posted Wed, 06 June 2007 at 3:01 AM
Have you try User settings? Try AA min 10, max 30, and AA quality 100%.
Does it do the same with other hair?
It seams to have to do with transparency. Take a look at your trans setting too.
Dale B ( ) posted Wed, 06 June 2007 at 6:32 AM
With transmapped hair, always check your transparency setting on the transmap. Poser and Vue handle transparency with different ends of the grayscale pallette, and the translation can get thrown off very easily....
dburdick ( ) posted Wed, 06 June 2007 at 8:38 AM · edited Wed, 06 June 2007 at 8:49 AM
You need to turn texture AA on which is off by default in both Final and Broadcast render settings.  You can either render in Superior mode or manually turn on Texture AA in the render settings.
estherau ( ) posted Wed, 06 June 2007 at 8:39 AM
transmap looks to be okay in the vue material editor. Trying that AA setting now. Noticed texture AA too. what's that for? I might try it nex. Love esther
estherau ( ) posted Wed, 06 June 2007 at 8:40 AM
aha - okay will cancel current render and try that. Love esther
estherau ( ) posted Wed, 06 June 2007 at 8:52 AM
much better with texture AA turned on! thanks. Now another problem is the hair seems to have some stripes - see above image. Love esther
estherau ( ) posted Wed, 06 June 2007 at 8:06 PM
Oh, just tried a big render using boradcast in user mode, so I could up the AA settings to the ones suggested by vincebagna but with texture AA on, however it still looks bad. What does the texture filtering and recompute subrays thingy do? Love esther
estherau ( ) posted Wed, 06 June 2007 at 8:12 PM
here it is
dburdick ( ) posted Thu, 07 June 2007 at 12:05 AM
Are you using some sort of blur settings on the camera?  If so, this could be causing the problem because the transmapped hair strands are getting mixed into the blur.  If you want to create a blurred background you can do one of two things:
1.  Render the image without any blur and then use the depth map to create the blur in Post
  1. Do a 2 pass render one with the blur minus the hair, and one without the blur with only the hair and body and then composite them together in Post.
estherau ( ) posted Thu, 07 June 2007 at 12:33 AM
yes, i did have dof - now it doesn't but i also adjusted the texture filtering and recompute subrays thingy and the problem with the hair tips is gone love esther ps if it comes backwhen i render with dof then i will try your suggestions
estherau ( ) posted Fri, 08 June 2007 at 8:14 AM
Yep, I think dof was the main culprit. Love esther
Valerian70 ( ) posted Tue, 10 July 2007 at 2:06 PM
Just solved my problem THANKS.
I'm currently trying out Vue6 Esprit and my sticking point was the horrible treatment of eyelashes and hair in final render.  Thanks for the tip and hopefully the quick render I'm about to run on hair and lashes will lead to me buying this program...........like I really need another ;o)
