Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
export vickie head as a .obj file then her eyes (separately) then get rid of vicky, load up mikey. turn mikey's head invisable import vicky's head match up mikey body to vickey's head (don't move her head) then choose mike's head and in the object menu "replace body part with prop" (vickey's head will then turn invisible, but don't panic just choose the object prop's and make it visible again)load in vickey's eyes (keep track of which is left and which is right) choose one of mike's eyes and replace with the matching eye for vicky, repeat. save this critter to a character library. in order to get the morphs for vickey's head you will need to use morph manager, load in the hybid's .cr2 and vickey's .cr2, and just copy the morphs from vickey's head to your cyborg. the biggest problem you should run into is when you try to bend the head, maybe you can get around this by using the joint between the upper & lower neck instead of bending the head itself. good luck ShadowCat
How would I construct such a strange creature? -WTB
