Mon, Nov 25, 11:55 AM CST
Subject: Victoria 3 UV map conversion for V@ maps
Nukeboy ( ) posted Wed, 18 July 2007 at 11:34 PM · edited Mon, 25 November 2024 at 11:53 AM
I recently swapped computers, I know I have it somewhere, but does anyone have the file (even just the name) that reconfigures the V3 UV map to V2 (it lets you use all of the V3 morphs with a V2 texture)?
Thanks,
Going nuts...
modus0 ( ) posted Thu, 19 July 2007 at 6:24 AM
Attached Link: Ultimate Texture Converter
You could try getting the Ultimate Texture Converter utility available at DAZ, it allows (via plugins), texture conversion between Michael 1-3, Victoria 1-3, Aiko 3, David, Hiro, The Freak, Stephanie, Stephanie Petite, Luke, Laura, Matt, and Maddie.
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
EnglishBob ( ) posted Thu, 19 July 2007 at 6:36 AM
I know I have this - all my early V3 renders were made using V2 textures. I don't know what the situation was regarding redistribution, but once I get home I'll search it out. I can at least let you know what the file name was. ;)
icprncss2 ( ) posted Thu, 19 July 2007 at 7:46 AM
The UVS for remapping V3 to use V2 textures used to be on the product page of the V3 base figure.  Here's the blub from the DAZ FAQ about how to do it.[
http://www.daz3d.com/i.x/faq/0/-/?id=111](http://www.daz3d.com/i.x/faq/0/-/?id=111)
EnglishBob ( ) posted Thu, 19 July 2007 at 4:06 PM
The download was called Victoria3UVs.exe, which gives you two UVS files: blMilWom_V3_V2UVs.uvs and blMilWom_V3_V2UVs-mat.uvs. There isn't a readme, but I assume the usual DAZ terms apply, meaning no redistribution. Victoria3to2UVfix.zip followed, containing blMilWom_V3_V2UVsFIX.uvs which I think was made by Netherworks. According to my notes, this fixes a fault in blMilWom_V3_V2UVs-mat.uvs. Hope that helps you to find the files.
jonnybode ( ) posted Thu, 19 July 2007 at 4:19 PM · edited Thu, 19 July 2007 at 4:20 PM
HI!
I asked at Daz for that file bout a year ago but got no clear answer, they only pointed me to some program that converts textures between characters.
Dived deep into some old CD's and found the file there, strange how things have turned out, one finds it more easy to browse the Internet for files then in the own backyard.
Anyway I dont think the Victoria3UVs.exe is to be found at Daz anymore.
Regards / Jonny
byAnton ( ) posted Thu, 19 July 2007 at 8:35 PM
Daz has theV3 obj still with the original V2's Uv's. The new V3 UV's came later.
Since so much time has past, email them again and see if they might put it up for sale or as a freebie.
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
Nukeboy ( ) posted Thu, 19 July 2007 at 9:42 PM
Thanks, all!  I coulda swore that it was a freebie here and not DAZ, but that might be why I can't find it.  I got a ton of CD's I've burned with the very efficient title on all discs, "DAZ Files."
Guess I'll spend a couple of hours searching...
Thanks again.
NB
