Mon, Nov 25, 6:25 PM CST
Subject: Shading rate on body parts
stormchaser ( ) posted Fri, 20 July 2007 at 11:17 AM · edited Mon, 25 November 2024 at 6:25 PM
OK, I feel like a bit of a dunce here, but here goes.
I generally have my render shading rate at 0.2, which is also the same rate for figure parts etc by default. I used to have my shading rate lower but then I found out  that going below 0.2 in the render settings will have no effect if the body parts aren't also changed to below 0.2. Now my question is this, do I need to change every single body part's shading rate? I ask this because there are so many parts if you include just what's in the hand alone. Is there a way with one click that the entire body's shading rate can be changed, or will a python script be needed for this. I've tried a search but couldn't find anything. I guess I can ask over at the Python Scripting section.
Thanks.
nruddock ( ) posted Fri, 20 July 2007 at 1:49 PM
The shading rate for an item is the higher of the rate set on the item and the rate set in the Render Settings.
If you need a small shading rate value, you therefore must adjust both the value in the Render Settings and the value on any body parts or props that need a lower shading rate.
I think somebody did do a script to set everything in the scene to a shading rate of 0, allowing the Render Settings value to determine the shading rate.
Miss Nancy ( ) posted Fri, 20 July 2007 at 2:04 PM
we'll try to find out who wrote the script that changes all objects' shading rates. something to add to the poser 8 alpha, anyway. along with steve's texfiltering script.
stormchaser ( ) posted Fri, 20 July 2007 at 2:09 PM · edited Fri, 20 July 2007 at 2:09 PM
Thanks nruddock & Miss Nancy.
I hope I can get my hands on a script, it would just save so much time than having to go through each body part.
I've just been using the texture filtering script & that is a good time saver as well.
nruddock ( ) posted Fri, 20 July 2007 at 4:30 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=1968722&ebot_calc_page#message_1968722
Found the thread, ockham did one.
It's P5 vintage, but I'm sure it can be tweaked if there are problems with P7.
Miss Nancy ( ) posted Fri, 20 July 2007 at 4:36 PM
file_383466.txt
attached is a modified version of one of svdl's scripts. lemme know if it works.
carodan ( ) posted Fri, 20 July 2007 at 5:31 PM
Be warned however, lowering min shading below 0.2 (with the bodyparts set to 0 etc) can add a heap of render time. Nice details though.
PoserPro2014(Sr4), Win7 x64, display units set to inches.
                                      www.danielroseartnew.weebly.com
Miss Nancy ( ) posted Fri, 20 July 2007 at 6:47 PM
setting 'em all to zero means that the setting for all of 'em becomes whatever's in the render settings screen (as mentioned by noel above).
stormchaser ( ) posted Fri, 20 July 2007 at 9:14 PM
Thanks for the links nruddock & Miss Nancy, very much appreciated. I'll be doing a test later on today, I'll let you know how it works.
carodan - I'm one of those people who don't mind waiting hours & hours for renders to finish, it's all about the finished picture. I render alot in Vue with spectral atmospheres etc so long render times are the norm for me!
stormchaser ( ) posted Fri, 20 July 2007 at 9:27 PM
I should have gone to bed, but I had to give it a try. Yes, the script works!!
Again, thanks alot.
