Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
The shading rate for an item is the higher of the rate set on the item and the rate set in the Render Settings.
If you need a small shading rate value, you therefore must adjust both the value in the Render Settings and the value on any body parts or props that need a lower shading rate.
I think somebody did do a script to set everything in the scene to a shading rate of 0, allowing the Render Settings value to determine the shading rate.
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=1968722&ebot_calc_page#message_1968722
Found the thread, ockham did one.It's P5 vintage, but I'm sure it can be tweaked if there are problems with P7.
Be warned however, lowering min shading below 0.2 (with the bodyparts set to 0 etc) can add a heap of render time. Nice details though.
PoserPro2014(Sr4), Win7 x64, display units set to inches.
www.danielroseartnew.weebly.com
Thanks for the links nruddock & Miss Nancy, very much appreciated. I'll be doing a test later on today, I'll let you know how it works.
carodan - I'm one of those people who don't mind waiting hours & hours for renders to finish, it's all about the finished picture. I render alot in Vue with spectral atmospheres etc so long render times are the norm for me!
OK, I feel like a bit of a dunce here, but here goes.
I generally have my render shading rate at 0.2, which is also the same rate for figure parts etc by default. I used to have my shading rate lower but then I found out that going below 0.2 in the render settings will have no effect if the body parts aren't also changed to below 0.2. Now my question is this, do I need to change every single body part's shading rate? I ask this because there are so many parts if you include just what's in the hand alone. Is there a way with one click that the entire body's shading rate can be changed, or will a python script be needed for this. I've tried a search but couldn't find anything. I guess I can ask over at the Python Scripting section.
Thanks.
