Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 9:45 pm)
Hugz from Phoenix, USA
Victoria
Found it! You were correct surreality. the displacement map i had in the head skin map was getting in the way of the brows. when I cleared the displacement check box in the material room for the head tex-map, my brows rendered as they should with "Use displacement Maps" checked in render settings. Thanks to both you, surrealtiy, and Victoria_Lee for your help. I'm still a student of poser and i have just been taught. Thanx again.
Quote - I have another question though. Is their any way to make an INJ pose to toggle visiblity of the eyebrows so that when the user click on it from the library the eyebrows become visible and hide when the REM is clicked? just curious. thanx. and thanx for your help.
Can't do that because it's not a morph that's being injected, it's a material zone that has to be enabled to work. I'm working on a new V4.1 character and I've put detailed instructions on how to enable and use transmapped eyebrows in the Readme. I've, also, made sure my displacement mapping doesn't hide the zone, which is what was happening to you.
You're welcome for the help. I've learned a lot in these forums and I try to pass on what I was taught to others. That's what makes the forums so nice.
Victoria
