Forum Moderators: RedPhantom
Hugz from Phoenix, USA
Victoria
Found it! You were correct surreality. the displacement map i had in the head skin map was getting in the way of the brows. when I cleared the displacement check box in the material room for the head tex-map, my brows rendered as they should with "Use displacement Maps" checked in render settings. Thanks to both you, surrealtiy, and Victoria_Lee for your help. I'm still a student of poser and i have just been taught. Thanx again.
Quote - I have another question though. Is their any way to make an INJ pose to toggle visiblity of the eyebrows so that when the user click on it from the library the eyebrows become visible and hide when the REM is clicked? just curious. thanx. and thanx for your help.
Can't do that because it's not a morph that's being injected, it's a material zone that has to be enabled to work. I'm working on a new V4.1 character and I've put detailed instructions on how to enable and use transmapped eyebrows in the Readme. I've, also, made sure my displacement mapping doesn't hide the zone, which is what was happening to you.
You're welcome for the help. I've learned a lot in these forums and I try to pass on what I was taught to others. That's what makes the forums so nice.
Victoria
Here I have 2 renders, one is with the head made invisible in params and the other obviously visible. the eyebrows body part is visible in both renders. As you can see in the head_invisible shot, you can see the eyebrows. the head body part has a head texture map with eyebrows removed. I want to change the color of the brows. How do make the eyebrows show on the head with both visible? their are no params to transform any part of the eyebrow body part in v4.1 Any suggestions would be appreciated.
