Blender F.A.Q (Last Updated: 2025 Jan 23 10:50 am)
I'm not sure if you would consider any ot these the long way round / easy way to do it! but I would tend to do the first option.
Opt 1:
Create a cylinder,
Select every 2nd face
press e to extrude, but don't extrude to any great distance,
press s to scale and scale out the gear teeth - the teeth ends will now be way too big
switch to a side view press s to scale followed by x y or z to limit the scale along the axis of the cylinder and scale the width of the teeth down
tweak the rest of the scaling on the teeth end to give a gear.
Opt 2:
Create a nurbs curve in the cross section shape of the gear wheel
extrude
convert to mesh
(not sure if the steps are exact for opt 2 haven't played with nurbs / splines much in blender yet - but it'd work fine in Max...)
Toolset: Blender, GIMP, Indigo Render, LuxRender, TopMod, Knotplot, Ivy Gen, Plant Studio.
That's pretty much the way I expected to do it really. I asked because I came across a tutorial for one of the higher end applications that had a modifier that would do the job in one go. I believe it was called sub-D or somesuch although I can't remember which app it was. Just wondered if Blender had something similar as I haven't really played with its modifiers much.
You could model one tooth and do a 'SpinDup' ( I think is the right one.)
Reddog9
Tutorials, Samples and Models
www.blender3dclub.com
Here are two scripts for gears: I have seen good comments on the second one but never used either myself.[
http://www.len.ro/work/blender](http://www.len.ro/work/blender)
Quote - Thanks for those. The second one definitely looks the more promising, although it may produce more detailed gear (read no. of verts)than I need to use. Definitely a keeper though.
How about using the 'Optimize' script? Hmm?
It is better to do one thing well, than to do many things and excel at nothing.
As asked above really? Is there a way to do this easily or is it necessary to do all the teeth independantly. Any help appreciated.
