Wed, Nov 20, 2:39 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Size Problem...
Kaji ( ) posted Fri, 17 August 2007 at 6:40 PM ยท edited Wed, 20 November 2024 at 2:39 AM
I've got something of a size problem with xStream and Cinema...
I've imported a Poser figure into xStream with a tree to show you the difference in size between and an interPoser import. Since the bottom figure is way up in the sky you lose so much detail on the ground and there's a lot of haze. I set the aerial perspective to 1, which seemed to help a little... what other settings should I be using on the Vue textures?
bruno021 ( ) posted Sat, 18 August 2007 at 3:52 AM
Interposer imports never worked for me, the size is way too small,
Kaji ( ) posted Sat, 18 August 2007 at 8:45 AM
interPoser is too huge for me! I guess I could just do the scene in xStream, but with my old computer I found that Vue had a horrible time with Poser textures and would always run out of memory. :m_letdown:
