Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
I've imported a Poser figure into xStream with a tree to show you the difference in size between and an interPoser import. Since the bottom figure is way up in the sky you lose so much detail on the ground and there's a lot of haze. I set the aerial perspective to 1, which seemed to help a little... what other settings should I be using on the Vue textures?
