Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
I've used Carib's wonderful dynamic stuff loads of times with P6 and 7 so I'm thinking you have something else wrong here!
Which version of Poser are you using, is it up to date with all the required updates?
What's your pc spec?
Do you have anything else running that might be interfering with it?
Injustice will be avenged.
Cofiwch Dryweryn.
your mistake i'm afraid, not Carib's, you are starting your simulation with the "Start draping from zero pose" option checked, in the simulation options, you need to uncheck this to start the simulation calculations from the adjusted pose, and not the "zeroed pose"
with it checked it is gonna alter the V3 pose back to zero, which is how it was before you adjusted the pose to fit inside the gown, you should always adjust the figure pose to fit the gown as you do not know whether the cloth was actually made for the default vicky or one that had had a morph already applied to it.
also worth checking (as i can't see your results) that you have the cloth colliding against V3 figure ( that's where you will see the checked "start draping from zero pose"option) and maybe the ground (if nessersary) a good tip is to hide the hair (if already placed on figure) before selecting the "collide against" options, as with it hidden you get into less trouble during the simulation calculations.
hope that fixes it for ya.
http://www.philc.net/CC_sampleVideo.htm
Try this tutorial.
say." - Ghandi
i was only windin' you up,
glad it fixed it, i always make sure that there is no poke through too, others say they don't get problems even if they have poke through but i always have, so i always pose the arms, shoulders,forearms to fit the cloth, sometimes i scale the cloth a bit x,y,z if i'm playing with big boobies (but that's another story)
Frames set to 30 on the New Simulation button and the counter at the bottom, and the thing's gone beresk (as we say in the wilds of Geordieland), 118 frames and counting, at high speed too,.... I can't switch Poser off, it even overrides the Task Manager End Task button. When I stopped laughing I pulled the plug out.......
The real problem is the Cloth Room is failing to drape Carib98's excellent peasant gown to Vicky 3. Following the tutorials here, the gown arms go nowhere near Vicky's arms when loaded in the Pose Room, zeroing her and the gown makes no difference at all. There is no way the gown can be scaled or moved so that the arms fit Vicky's arms while the rest of the gown stays on her body.
If I physically move her shoulders and forearms in the Pose Room to fit the gown arms, the Cloth Room moves them back again. The drape fails every time, I'm stuck.
Is theren a way of 're-matching' figure and clothing, perhaps by parenting and saving to the library and bringing back??
Carib98 - beautifully done piece of kit.
