If you are real good you can paint this type of effext in by hand using the blur brush in photoshop and the doge and burn tools. Or as I did in this inage, I applied a KPY filter called turbulence. You need to do it in the actual image layer though, this will not work on a added layer. You mask out the object you wish to have the disturbance around. Then you go into KPT plugs and select the turbulence plug in. Set the dampening half way. The brush size to the smallest setting and distortion above the half way mark. You may need to experiment with the settings a bit. Then you drag your mouse across the object near the water line. Try varying directions or move your mouse in a circular motion and see how the ripples expand. The trick is that you need to hold your other hand over the enter key on the keyboard. When you think the ripple pattern is the way you want it hit enter this will freeze the effect and apply it to your image. In the preview the entire object will be distorted but don't worry the main image will not have the distortion applied to the area you masked in step one. To touch up use the smooth and blur tools to tidy up the ripples. This is a trial and error way of doing it but it is easy and quick enough to get good results in short order. You may even wish to experiment with multiple passes. This technique can also creat realistic bump and ripple texture maps. Convert a ripple image to gray scale and import it into the terrain editor can create your own ripple and wave objects.
Just for our understanding (we are a little bit new in this topic, got our Bryce 4 three weeks ago): - first you create a 2D image with water-swirls/turbulences in any painting program (like photoshop) - Then import this image into Bryce as texturemap - Bryce is transforming this texture into a 3D-surface??? Please tell us, how to convert an image to a texturemap or get this result, which is shown above. We for ourself, had choosen a (perhaps very cryptical) way to creat waves in a rough sea: In RDS we build our sea, based on a flat surface with 50 facets in x and y. We did the modelling and at the end we got our rough sea as *.obj and imported it into Bryce. Greetings Matthias + Daniel
In addition to all the above metioned ideas, try some alpha-channel driven specularity and/or reflection on the surface of the object and position it so that it corresponds to the water/object intersection point/line, giving and effect of wetness ect, also have your objects texture customized in respect to colour so it appears "wet"....The real world Bryce2 (and probably the lastest addition also) book also has some good ideas to offer on this subject...
On several renders here and in the gallery, I notice that when people or objects are standing in or sitcking out of the water that there is an unrealistic border between the object and the water. The water usually has a nice texture / bump to it simulating a bit of turbulence or small waves but there is rarely any disturbance of that effect at the point where the water touches the object. I know that doing this accurately could be difficult, but I'm wondering if anyone has any tips on generating this effect...
